CTs phenolic tweeters ?
aje123
Well-Known Member
Why small magnet?
Can I use for the bigger magnet replacement
I picked up another set of speakers for parts.
Have CTS tweeters I need but smaller magnets !
Can I use these in place of the larger magnet ones? ThanksEA4DDFDE-F0EE-4E83-8327-7ECA34D3A627.jpegA2556042-F1A4-493A-BE4C-D9B67C72F217.jpegEA9C918A-94B3-4BB0-B661-225C27EB3E74.jpegAEA360B6-4DAA-4111-857E-4D73EB8E002A.jpeg
Probably an older version with an alnico magnet, which are smaller, but should work ok as a replacement.
Could be that different speaker makers specified things differently. Otherwise I don't have a clue. Sorry.
John
Originally CTS had several versions. And 8 ohm and 4 ohm that I know of, maybe even 16 ohm depending on what the speaker manufacturer wanted? Later they were made in Taiwan. The ones PE sells are either Taiwan or Chinese made.
If I remember right, the magents on the CTS made phenolic ring tweeters in my Imperial 6's and 5's are larger than the clones PE sells.
Yes, highly regarded the CTS ones. Thanks
I remember them in speakers in the 70s. But never in mid or high end speakers. That’s why I asked. Bose loved to use paper cone tweeters.
These look to be decently well made:
Wharfdale used these in the early to mid 60s. Cone breakup and beaming were its issues. Felt surround.
I tend to like soft dome tweeters, but the CTS phenolic ring tweeters are one paper cone tweeter I like. My Imperial 5's and 6's aren't high end, but damn easy to listen to and they don't sound rolled off or shouty.
As I stated before, I do tend to prefer soft domes mostly. Silk, doped cloth, etc. But there are some nice sounding paper cone tweeters. I even have a pair of small Realistic Optimus 2B's that have paper cone tweeters that sound decent.
I just haven’t found a paper cone tweeter that has agreed with me.
Back in ‘91 I bought this pair of Realistic speakers with paper cone tweeters.
It was only a month before I replaced the tweeter, and the 5-1/4” woofer while I was at it. I still play these today. Very good sounding small speakers. Again, I’m glad I chose a butyl rubber surround on the woofer (Peerless).
To get back to the original question the small magnet structure would be alnico versus the later and larger ceramic magnets used on the vast majority of CTS manufactured phenolic ring tweeters. I have never seen a CTS phenolic ring tweeter before with that small alnico magnet structure which CTS did use on earlier cone (non-phenolic ring) tweeters.
The only possible operating capacity issue between the two different magnet structure configurations is efficiency if they are both rated at 8 ohms as their volume outputs for a given input level may differ to some degree.
As an aside: CTS offered phenolic ring tweeters in both standard and high power handling versions, with the high power versions having a larger diameter voice coil (and dust cap) and a larger magnet structure. I've always much preferred using the higher power versions in my frankenspeaker projects over the years.
I agree, the tweeters with Alinco magnets should be more efficient, lower wattage, and need less power to drive them. So fiddling with resistor values, or using a Lpad may be needed if used in something other than the original speaker. The one PE sells is kind of a one size fits all version. Another difference I noticed is the original CTS phenolic ring tweeters tend to be good up to 18khz, where the PE reproduction is rated for 15khz. Not much of a difference really though.
From an ancient memory:
There were originally only two versions of the CTS phenolic ring tweeter - 2T8 and 3T2. IIRC, the first number was the voice coil size and the second was the magnet weight. I may be misremembering (it was close to 60 years ago!), but that's what I recall.
I know Marantz used both 8 ohm and 4 ohm versions also. 8 ohm in the Imperial 4's through 7's, and 4 ohm in either one or both the 8's and 9's if I remeber right.
I have a pair of those with the original drivers, and they might be the worst sounding speakers I've ever heard.
