Dahlquist dqm 9
pabaker
Can anyone help me locate a dahlquist dqm 9 tweeter. I have had no luck locating one, even called the company, and have yet to recieve a response. Thanks for the help.
I see the drivers come up on ebay on a fairly regular basis..also do searches on magnat as the dqm were rebranded magnats I have a pair of dqm-7's. They won't win any beauty contest but soundwise everything I've thrown at them comes up short
I have a pair of the 9's in great shape with the exception of the tweeter. They sound great, just need the tweeter to complete the picture.
They come up often enough on eBay. Otherwise, they're basically unobtanium. By the late '80s Dahlquist couldn't even source them. The service department resorted to modifying the casting to accept a Vifa D26tg.
So, keep an eye on eBay. Also, make sure the proper fuse is installed after you've found a replacement.
They have that same gunmetal gray as the Magnat larger drivers in there...
The service department resorted to modifying the casting to accept a Vifa D26tg....
Thanks for the model number for the Vifa.
Nominal impedance [ohm]
6
Voice coil resistance [ohm]
4.6
Nominal power [W]
100
Short term max power [W]
Long term max power [W]
Operating power [W]
3.2
Sensitivity [dB]
92
Frequency range [kHz]
3-30
Free air resonance [Hz]
1500
Voice coil diameter [mm]
26
Voice coil height [mm]
1.6
Air gap height [mm]
2
Voice coil inductance [mH]
Eff. diaphragm Area [cm²]
7.1
Moving mass [g]
0.27
Magnet weight [g]/[oz]
240/8.5
Force factor [Bl]
3.3
VAS [l]
Qms
Qes
Qts
OD:
104 mm
CD:
80 mm
FT:
ID:
27.3 mm
MD: 74.3 mm
HD:
4xų4@ų9
