Other than the name absolutely nothing in common with the company founded by Jon Dahlquist. I believe the name was sold to a Canadian company. The surviving engineer from the original Dahlquist who had designed the DQ-20 and DQ-LP1 variable electronic crossover had already left to start his own speaker company(Alon).
Those look fantastic Orionkc!
Maybe a dumb question... why are the woofer cones all covered it what appears to be "goop"... Did they come that way?
Hey Rick, Cheers from Canada![]()
I found a couple of 10" risers at Value Village. So I took off the short factory risers and put them on. The bass response is noticeably less boomy - much tighter. The balance between higher frequencies and the bass is better. I am once again impressed by these things. These Vifa drivers can be purchased pretty inexpensively and the crossovers look pretty simple. I would build a pair if I didn't have these!
It’s two 8” Vifa drivers, no passive. I hope you don’t own them.Sorry about the delay. It's a 1" dome tweeter and an 8" woofer with an 8" passive.
