Making some progress on the room. It'll be a while before I can get the ceiling speakers installed though - it's pretty toasty in the attic until about November in PHX. So for now, it's just 5.1. I used the 18" subs from my office system at the last home, converted them from ported to sealed, and have been playing with them a bit. I was able to find a nice location in the room which was conductive to both their physical location as well as them coupling well to the listening location.
The enclosures for each are 7.5ft^3 before displacement of the drivers, ports, and internal bracing. After I remove the ports (easily removed and swapped with plates - as I designed them that way), I'll gain about .55ft^3, so the net internal volume will be about 7.2ft^3. These drivers have an Fs right at 20Hz so perfect for this application. F3 is about 25Hz as they are now. I've used the DSP EQ in my Integra DHC-80.6 to smooth response as best as possible with pretty good results. [I should capture that with my RTA before proceeding.]
For now, the ports are simply stuffed with pillows. So, the plan is to remove and cap those, add arountd 8lbs of polyfil to each enclosure, and re-run the EQ.
I've been using my 7300 to power the subs with quite excellent results. Using them for music, the transition to the mains is so seamless you can't tell where the subs let off and the XRT22s begin. [I've got those set to Full Range, but the DSP in the Integra likes to high-pass them at 40Hz - ok.] On songs like Halos, from Alan Parsons DVD - From the New World, can only be described as breathtaking. The amount of first octave energy in the room (massive - I sit 20ft from the mains and 21ft from the subs) just has to be experienced. At first listen, you don't even realize how much energy the room contains, and then when you turn it down and leave the room, you can feel it on your ears. I don't even flicker the PG lamps on the 7300. Very impressive how well the system sounds as a whole.
However . . . the LFE track on Bluray True HD movie soundtracks is on a whole different level. That will, and without warning, flash the PG lamps on both channels, sometimes holding them ON for seconds at a time. No harm comes to the amp or subs when doing so, but a sure sign you're absolutely out of amplifier. And it just scares the living hell out of you when the entire room is pressurized like that in an instant. And that amp runs toasty serving LFE duty.
So, hopefully, I can make the cabs even more efficient with my short term plan to lessen the power required at 20-25Hz. Then, I'll swap to one of the 2500s which is at least fan cooled and has a few dB more output power. [The subs are a pretty benign load when I sweep the cabs with my impedance meter from 20-80Hz.] If that fails, then I have a Crown K2 in the wings. Either way, I will definitely have to employ the LFE limiter in the Integra to keep from damaging the woofers by overpowering them. A room this size would be better served by (6) 18" and a single 2500 . . .
News to follow.
