DC off-Set...
jleon92f
Addicted Member
Hi , I check my KR-5200 DC off set at the speakers and this was the result.
left: 17 mV
Right: 46 mV
Is this Ok for now?
Sounds good still.
Thanks,
John.:music::D
Left 17mV sounds good. Right 47mV is a little high and may need to check soon. But if it doesn't change from 47mV in the next couple of weeks (and month), may be it's OK to use it without fixing soon. But if you have the coins and knows the tech who can fix it for you, it's probably best to give it a thorough checkup. May be you can adjust DC offset yourself too.
EchoWars is the man you want to talk to in this thread.
http://www.audiokarma.org/forums/showthread.php?t=5634
Thanks,
I did not know you could adjust it. What is replaced when you do a repair? The outputs?
Thanks,
John.:music::D
Few Kenwood receivers allow for offset adjustment, but I don't think I'd lose any sleep over a reading of 46mV.
