Running a home for wayward DCM's ?
I would like to find a pair of TF-1000's to go with my 700's but I don't know where I'd put them. That's never stopped me before though....
Great thread and very resourceful. Thanks to all who contributed.
I'm a new member here because I've just purchased a set of Time Windows (probably 1A, but it's not stated anywhere on the speakers) that are in pretty good shape for $60 and I've been doing research on the various DCM speakers. Two of the Vifa tweets in the TW are blown so I'm going to replace them and I'm going to sand the oak tops and bottoms and refinish them.
I had a set of Time Frame 500's back in the late '80s and loved them. Still have most of the parts in storage and this winter I'm going to try to refinish and restore them, but with different drivers. They remind me of a time I'll always remember. Good times.
Frankly, I haven't had a lot of listen time with the TF1000s since they arrived. I did the JBweld patch on the bad rear panel and let it sit a day before I closed it up after work yesterday. I lacked time to do a good AB last night (took a dear friend out for dinner) - and I only played them maybe 30 mins or so before we headed out.
They are currently on the upstairs 2 ch music only system with the 40w/ch Jolida tube amp.
I played Zep (Gallows Pole) , some Miles (part of the In A Silent Way session), James Taylor (Millworker), Joni (Amelia & Hejira) and a bit of Yo Yo Ma ... all sound great -
but no time to compare ... even to the TF500s upstairs with them.
All the others (TF400/TF600/TF700) are downstairs on the home theater system - tho I am planning to bring at least one of each up for a group shot this weekend.
If it gets hot and muggy, maybe I'll have some playtime over the weekend.
To the best of my knowledge there have been two different versions of the original Timeframe speakers - the originals with no sock coverage on the backs and the series II with full sock coverage.So I am in a bit of a pickle here. I have a pair of TF-700's (the model that isn't totally enclosed by the sock) and I like them; but my uncle has what I believe are also TF-700's, but the sock covers the entire speaker.
Well, there goes my theory. I do recall though that my original TF-500's had foam surrounds. One woofer wore out and I contacted DCM and purchased a replacement woofer, which had a rubber surround. When I put it in the cabinet I noticed the speakers sounded a good bit different with tighter bass going to the newer driver with the rubber surround.His speakers sound better than mine. Whereas I understand that speaker placement, room acoustics, and other components play a big role in sound, I think that there may be something technically different between our models. When I contacted DCM, they told me that they only made one model of TF-700's.
Tough call, but IMO the tweeters on the TF-600's have a knack for blowing out, hence there is a strange light bulb fuse in the crossovers. The TF-600 tweeters are not currently available through DCM or Parts Express. Neither are the bulb fuses in the crossovers. The bulb fuse can be bypassed, but one would have to place a resistor (don't know the value) in the signal path to the tweeters to make up for the fuse.So my question is this: are there more than one model of TF-700's, and if not, is the TF-600 a better speaker? His speakers protrude deeper at the bottom of the speaker than mine, so I'm inclined to believe that there was more than one generation made. If not, would you replace TF-700's with the newer TF-600's?
Perhaps your uncle is also using a better amp? That can make a big difference along with room placement/acoustics.
The TF-700's use a Vifa tweeter and Parts Express does currently have a drop in replacement as does Madisound (Seas). These older Vifa tweeters were also used in speakers by Mission, Tannoy and others so they are pretty decent.
As for which set sounding better? That's very subjective and I don't have any experience with either set, although I'd love to happen on a set of TF-700's some day.
Again, just one guy's opinion.
Thanks for the feedback... I just got confirmation that my uncle' speakers are TF-600's, which explains the difference in the look and build of the speakers. I'm told that the 600's have a different configuration than the 700's, so that explains the difference in sound. To me, the TF-600's produce a better ambiance and depth of sound; although, I do quite like my TF-700's as well. I'm gonna look into some TF-600's and see what I can find. Thanks for your help. You made a newbie feel very comfortable asking questions on a public site.
I guess you never pushed those 500s much did ya Heather? First thing I did was crank up the bass and see what they could do. You'd be surprised how much they can shake a house.
Sent from my SPH-M910 using Tapatalk 2
Sure - but why push TF500s hard when I also had TF700s and TF1000s, both of which do go deeper.
Plus I have an 18 inch JBL 4641 sub in the corner with 600watts feeding it -
I don't have a lack of bass in that room!
But so glad to know you are enjoying them - it really is about the music and the smiles it brings!
Audysseys calibration was able to tune the DCMs to my tiny room better than I ever could...
Ahh yes, Audyssey... the greatest thing to ever happen to Home Audio IMHO!!! :thmbsp:
