Denon DP-47F Counter Weight
tinkerer
AK Subscriber
Can someone provide me the Weight and Thru Hole Dimensions of the Counter Weight for a Denon DP-47F Turntable.
Or if someone knows where I can buy one that would be great.
Thanks
Thanks mprince for the link.
Rob @ organdonorparts says the 35F is different than the 47f counterweight.
I'll give you two measurements because the inner diameter has a slippery tape applied:
Actual thru hole is 18.40 mm
with tape it is 18 mm
Unfortunately my wife informed me our old scale was kaput and thrown out so I ordered another (needed one anyway) will have it Saturday
Denon part number for reference of the silver:
3150314009
I believe the black is:
3150314012
Thank You so much Scott for the info.
There are reproductions on an auction site that may work if I can get the correct specs.
Regards....Jim
Hi Jim, it took a while but the weight of my black DP-47 counterweight is 99.75g. Let us know how things work out in case others need to follow a similar path. Hope things work out for you and the '47.
Thanks for the information, very much appreciate it.
I'll let you know if I find an aftermarket counterweight that fits.
Thanks again,
Jim
All I've found is a dead end. No one makes an aftermarket counterweight for the DP-47F that I can find.
Thanks for all the help.
Jim
