I would think the lightest lube available would be the best. My experience is that synthetic oil tends to stay 'oily' while 'natural' oil (if going thru a refinery can be called natural) tends to become 'gunky' after an extended period of time (years). If all ready difficult to remove I would think the lightest coating of whatever would be best. Now that I think of it, I have some fully synthetic bicycle grease I may try. Will apply with a Q-tip and wipe off all I can with a paper-towel, which should leave a very light coating. Won't happen until mid-July. Will be an annual PM just to guard against whatever is used drying out and becoming 'sticky'.Definitely worth trying. I have oil, and molybdenum grease — do you have an idea which might be better?
Unless @Mister Pig has a 2nd one in his barnyard, probably not.
I bought his DP-75 motor/platter and installed it on an existing Denon DP-6700 plinth. Then I installed a Technics EPA-500 arm on. I have 3 "tubes" for the EPA. So far I've installed a Ortofon MC-3000 and a Miyajima Madake and have been more than happy with the results.
The EPA-500 did require a 2 step drilling process.
You could say I'm as "Happy as a pig in s**t"
View attachment 1505521 View attachment 1505522
No offense but why not do something about covering the hole in the armboard? Curious about location as well. Did the prior owner have a linear tracker on there or did you rotate the armboard 180? Which is not possible on my DK110 as the design is asymmetrical. Denon did this in order to support removal of the armboard without needing to remove the drive. Curious if they did this on all the plinths where the armboard sits partially under the drive. I'm assuming so.
The Audiocraft does sound very good and yes, I think it looks the part where it is. The one drawback to the arm is that being a free-range unipivot in spite of taking a SME-type shell it isn't exactly a quick-change operation. It not only has a whole lot of parameters that can be adjusted, but each and every one of them must be dealt with. Adjust one and it changes the rest so it is a bit of a long rodeo from start to finish. Once set up it is nicely stable and I haven't had to touch a thing since I finally got it right. I do suspect I'd be rather quicker the next time around, plus I think part of what made things a moving target initially was that the arm was essentially NOS, things kind of broke in a bit and the damping fluid took its sweet time in completely settling as well.Absolutely no offense taken. I should have mentioned that the armboard is temporary. I need to make a new armboard and I will probably this fall. Most of my tools are at the vacation house on the coast, 390 miles away. I bought the DP-6700 about 6 years ago. It had a Denon DA-307 arm ot it. I've tried a few arms on the stock table incuding an Acos GST-801and each change brought something slightly different sonically.
Anyway, I realized I was out of armboards. That armboard is what arrived with the table, drilled out for the DA-307 and I was able to rotate it 180 degrees and use it.
If this plinth had been larger I might have installed a Sony PUA-1600L. I do have another, larger plinth with the DP-6700 motor. It has 2 armboards so I plan on installing the Sony PUA-1600L on the right side and the Acos Lustre on the back side
@fiddlefye your Audiocraft AC-400C looks stunning. If it sounds half as good as it looks it's a keeper
I was trying to figure out what stain to use on my plinth and had been considering a cherry or black walnut. However the rosewood plinth @Legrace has, might be the direction I go
As I don't use a plinth, I forgot...Since I have plinths on the brain I also just noticed that the DK100 plinth shared in post #10 has an intricate cut out where the rear of the drive resides. Mine does not have this.
I don't need it, but it sounds like a very worthy thing to do!As I don't use a plinth, I forgot...
I have Denon's original template for the cut-out. My DP-80 came with all associated documents. It's not a sketch, it's a precise engineering diagram at 1:1 scale. "Intricate", as Legrace describes it. I think it was intended for radio stations: lay it flat on the console and trace through it, then cut. Easy with a saber-saw (jigsaw) — unless you're making a plinth from slate or a meteorite.
If it's of use to anyone, I can dupe it. It will have to be a photo, scaled down. But the correct dimensions/
distances are on the template — it's easy to calculate the % enlargement. I've printed a few arm-mount templates and protractors and the print-outs are exact.
Let me know. It'll take some time. I must find the folder, and the time, and set up to shoot it so there's no parallax or spherical distortion; not difficult, but not a speedy process.
Not that bad. A puzzle with only two pieces, with straight sides and lines that line-up. It'll fit on two sheets of 81/2 x 11, with the fat part (the controls in front) centered on the 11" seam. If your printer is 11 x 17, one sheet.Print that out in 1 to 1 scale and be prepared to assemble a jigsaw puzzle.
Suspense, and the slow reveal, while the world wonders What turntable can it be? — your narrative MO. I a voyd guesswork, I'm not an oracle, I'm not even tempted to try.But as I said I love turntables, and there currently is one kind of rare bird out there on the used market that is calling to me. A sirens song I am trying to resist, but its been very hard. Yes its a belt drive, but its an iconic table, looks to be in perfect condition, and redefined what analog playback was in the late 80's and early 90's. I shouldn't buy it, but I should because like the SP 10 MK II I have its in perfect condition and hard to find.
