And I removed TR511 and it's heat sink. It tests good.
James
,James
,Maybe a few months on the shelf will be a good thing!I just took a detour and looked over the 3rd, damaged amp. I'm thinking that it looks repairable. There are a couple of damaged traces to fix but they don't look terrible.
Someone has done lots of things in there. It has been at least partly re-capped, mostly with Roederstein, which are actually not bad. Whoever it was put a 22µF63v cap in place of C524, one of those 1µF things that we were talking about.
The drivers have been replaced with ISC 2SA1006 and 2SC2236, which are not a completely bad choice I think, 25w, but only 80mhz.
They unwrapped the wire wrap posts, so that sux.
2 of the outputs have been replaced with ISC parts, one in each bank, and both are shorted.
I'm thinking that after I get some other projects out of the way I will revisit this thing, late summer or Fall, and get it working.
Cheers,
James
For that one perhaps, there is no rush with that one, it will just be my backup. But I would really like to get 2 of these working soon.Maybe a few months on the shelf will be a good thing!
,It's an elegant design. I'm more repairman minded then design & analysis. It's been 30 years since I went to op amp school. But I do remember their feedback loops are crucial for gain & stability.OK, very good to know, thanks!
Just to help an old mechanic understand can you share some of the secrets of knowing that about these positions? Because I would never have twigged to that and this seems like a good chance to learn something.
Based on your advice I swapped C523 with a Panasonic FR 10µF/50v.
C524 & 525, I could temp re-install the originals until I can buy some elcos so that I can test the amp. They aren't great, tested at about 900nF and 5.9 and 7.5 ohms ESR.
I found some Kemet 1µF/100v elcos that look decent.
https://www.mouser.de/ProductDetail/KEMET/ESL105M100AC3AA?qs=HXFqYaX1Q2x0RWu/YCFzZA==
But that will have to wait until I'm back from vacation.
Cheers,
James
Cool....typical of the burn outs I've seen before. I'd focus on the PNP side if ya suspect further issues.And I removed TR511 and it's heat sink. It tests good.
Wtf is up with that? Looks like a dude stuffing his pants. I'd put that diode on the boards bottom. WeirdThat little devil has snuck right between the legs of TR510.
OK, thanks for the info. I'm still a bit confused because I thought that a cap would block DC regardless of direction and regardless of it being NP or not.It's an elegant design. I'm more repairman minded then design & analysis. It's been 30 years since I went to op amp school. But I do remember their feedback loops are crucial for gain & stability.
Fellow mechanic point of view...Don't connect your battery backwards, lol. Bad things happen. Polarized caps are like batteries.Those 3 polarized caps we're talking about are designed to be a one way street for DC. They block DC and pass AC. Notice the anodes of those 3 are tied to the positive source, +15v & +1.8. The cathodes are tied to the negative source. -15v & -1.8. I think the NP Wima's are cancelling the feedback loops to the op amp.
,2SA968B>MJE15033
Nashou
,Don't know yet. I'll be finding that out today.Cool....typical of the burn outs I've seen before. I'd focus on the PNP side if ya suspect further issues. Is R565 or 566 open?
,Wtf is up with that? Looks like a dude stuffing his pants. I'd put that diode on the boards bottom. Weird
,I thought the polarized caps charge up at one half cycle and discharge on the other half cycle for regulation and stability.OK, thanks for the info. I'm still a bit confused because I thought that a cap would block DC regardless of direction and regardless of it being NP or not.
Nonetheless I will take the advice to heart.
James
That sounds right. I am not as good at this stuff as you may think. In any case, I am heeding your advice and will not go forward with the film caps in those positions. Better a delay than a disaster.I thought the polarized caps charge up at one half cycle and discharge on the other half cycle for regulation and stability.![]()
,Hi James,
I now saw your POA-6600 thread.
I'm curious to know how the OPA1642 performed in your monoblock amp. I have a Denon PMA-737 integrated which uses the M5218 as DC Servo, too. After putting in an IC socket and trying a bunch of different opamps, I found that the "old" FET input TL072 vastly outperforms the stock one and is even better than the 5532. But this was in the PMA-737.
An opamp acting as DC Servo is almost always in the audio path, so I wanted to try a few ones, including newer ultra-low noise ones.
I just wanted to share this here: a while ago, last year, I was advised to increase the supply capacitance from 47uF to 100uF for the opamps to guarantee that their Icc (supply current) wouldn't drop with the voltages too much using another opamps with a higher Icc like the 5532 (8mA to 16mA!!!), but that did not happen. I left the 100uF caps in any way because they are new caps. Supply voltage dropped from 14.9V to 3V using OPA2134 and the L1113 and DC offset raised to over 250mV with them. OPA2107 was okay with current and voltage but the sound was pretty much the same as the M5218P.
The 5532 (BJT) sounded dull and lifeless, worse than the stock M5218. But the TL072 surprisingly sounded much more vivid with no voltage/current drop. The other good thing about the TL072 was that the DC offset dropped from ~5mV (stock M5218) to around 1.4mV.
Below is a quick list of the opamps used in place of the Mitsubishi M5218P, which is not (nowadays) considered a good opamp for audio.
A quick reference of parameters:
Opamp - noise in μV or nV - bandwidth in MHz - slew rate in V/μs - Supply current (Icc) in mA - topology BTJ or Fet
M5218P - 2μV - 7MHz - 3V/μs - Icc 3mA ~ 6mA (p/ch) / BJT
TL072 - 15nV / 4MHz / 16V/μs / Icc 1.5 ~ 2.5mA (p/ch) / Fet
OPA2107 - 8nV / 4.5MHz / 18V/µs / Icc 4.5 ~ 5mA (p/ch) / Fet
LT1113 - 4.5nV / 5.6MHz / 3.9V/μs / Icc 5.3 ~ 6.5mA (p/ch) / Fet
JRC4558 - 8nV / 3MHz / 1.7 V/μs / Icc 3.5 ~ 5.7mA (p/ch) / BJT - 178mV
OPA2134 - 8nV / 8MHz / 20V/μs / Icc 4mA ~ 5mA (p/ch) / Fet
NJM2068 - 0.56µV / 27MHz / 6 V/μs / Icc 5mA ~ 8mA (p/ch) / BJT
NE5532 - 5nV / 10 MHz / 9V/μs / Icc 8mA ~ 16mA (p/ch) / BJT
* Still to try out (sometime in the future) ==================
* OPA1678 - 4.5nV / 16MHz / 9V/μs / Icc 2mA ~ 2.5mA (p/ch) / CMOS
* OPA1642 - 5.1nV / 11MHz / 20V/μs / Icc 1.8 ~ 2.3mA (p/ch) / Fet
* OPA2189 - 5.2nV / 14MHz / 20V/μs / Icc 1.3 ~ 1.7mA (p/ch) / CMOS
* OPA2210 - 2.2nV / 18MHz / 6.4V/μs / Icc 2.2 ~ 2.5mA (p/ch) / BJT
* OPA1662 - 3.3nV / 22MHz / 17V/μs / Icc 1.5 ~ 1.8mA (p/ch) / BJT
* OPA1602 - 2.5nV / 35MHz / 20V/μs / Icc 2.6 ~ 3.2mA (p/ch) / BJT
* OPA1688 - 8nV / 10MHz / 8V/μs / Icc 1.6 ~ 1.8mA (p/ch) / CMOS
