Hi James,
I now saw your POA-6600 thread.
I'm curious to know how the OPA1642 performed in your monoblock amp. I have a Denon PMA-737 integrated which uses the M5218 as DC Servo, too. After putting in an IC socket and trying a bunch of different opamps, I found that the "old" FET input TL072 vastly outperforms the stock one and is even better than the 5532. But this was in the PMA-737.
An opamp acting as DC Servo is almost always in the audio path, so I wanted to try a few ones, including newer ultra-low noise ones.
I just wanted to share this here: a while ago, last year, I was advised to increase the supply capacitance from 47uF to 100uF for the opamps to guarantee that their Icc (supply current) wouldn't drop with the voltages too much using another opamps with a higher Icc like the 5532 (8mA to 16mA!!!), but that did not happen. I left the 100uF caps in any way because they are new caps. Supply voltage dropped from 14.9V to 3V using OPA2134 and the L1113 and DC offset raised to over 250mV with them. OPA2107 was okay with current and voltage but the sound was pretty much the same as the M5218P.
The 5532 (BJT) sounded dull and lifeless, worse than the stock M5218. But the TL072 surprisingly sounded much more vivid with no voltage/current drop. The other good thing about the TL072 was that the DC offset dropped from ~5mV (stock M5218) to around 1.4mV.
Below is a quick list of the opamps used in place of the Mitsubishi M5218P, which is not (nowadays) considered a good opamp for audio.
A quick reference of parameters:
Opamp - noise in μV or nV - bandwidth in MHz - slew rate in V/μs - Supply current (Icc) in mA - topology BTJ or Fet
M5218P - 2μV - 7MHz - 3V/μs - Icc 3mA ~ 6mA (p/ch) / BJT
TL072 - 15nV / 4MHz / 16V/μs / Icc 1.5 ~ 2.5mA (p/ch) / Fet
OPA2107 - 8nV / 4.5MHz / 18V/µs / Icc 4.5 ~ 5mA (p/ch) / Fet
LT1113 - 4.5nV / 5.6MHz / 3.9V/μs / Icc 5.3 ~ 6.5mA (p/ch) / Fet
JRC4558 - 8nV / 3MHz / 1.7 V/μs / Icc 3.5 ~ 5.7mA (p/ch) / BJT - 178mV
OPA2134 - 8nV / 8MHz / 20V/μs / Icc 4mA ~ 5mA (p/ch) / Fet
NJM2068 - 0.56µV / 27MHz / 6 V/μs / Icc 5mA ~ 8mA (p/ch) / BJT
NE5532 - 5nV / 10 MHz / 9V/μs / Icc 8mA ~ 16mA (p/ch) / BJT
* Still to try out (sometime in the future) ==================
* OPA1678 - 4.5nV / 16MHz / 9V/μs / Icc 2mA ~ 2.5mA (p/ch) / CMOS
* OPA1642 - 5.1nV / 11MHz / 20V/μs / Icc 1.8 ~ 2.3mA (p/ch) / Fet
* OPA2189 - 5.2nV / 14MHz / 20V/μs / Icc 1.3 ~ 1.7mA (p/ch) / CMOS
* OPA2210 - 2.2nV / 18MHz / 6.4V/μs / Icc 2.2 ~ 2.5mA (p/ch) / BJT
* OPA1662 - 3.3nV / 22MHz / 17V/μs / Icc 1.5 ~ 1.8mA (p/ch) / BJT
* OPA1602 - 2.5nV / 35MHz / 20V/μs / Icc 2.6 ~ 3.2mA (p/ch) / BJT
* OPA1688 - 8nV / 10MHz / 8V/μs / Icc 1.6 ~ 1.8mA (p/ch) / CMOS
As they say, "I'm working on that"
,When I was first testing the first amp and before I got it working I also noticed that installing anything other than the stock op-amps dropped the supply voltage. I'm pretty sure that the amp was oscillating and changing the op-amps just made it worse.Supply voltage dropped from 14.9V to 3V using OPA2134 and the L1113 and DC offset raised to over 250mV with them. OPA2107 was okay with current and voltage but the sound was pretty much the same as the M5218P.
Yes. Other than the Zeners, the 47uF supply caps in the 737 needed to be increased to 100uF to provide an adequate power reserve for the other Opamps.When I was first testing the first amp and before I got it working I also noticed that installing anything other than the stock op-amps dropped the supply voltage. I'm pretty sure that the amp was oscillating and changing the op-amps just made it worse.
Also almost all of the zener diodes were working at 0.2v to 0.4v lower than spec, so the supply rails were low to begin with. Replacing the zeners and the transistors in the voltage amp section seems to have made a big difference and I could at least put a TL082 in the amp without the supply voltages dropping. I haven't gotten any farther than that yet.
If your supply voltages are only 14.9v, and if they are supposed to be 15.1v like my amp you might want to check those HZ-15-2 zener diodes.
James
Thanks for the kind thoughts.Yes.
My main goal with the PMA-737 was/is to see if a more precise (and suitable) opamp as DC servo could reduce even further the DC offset.
The "rough" M5218P keeps it around 5mV, not bad. But I thought a newer modern opamp, being in the signal path, with lower noise, Fet/Cmos input, and low Icc consumption could do it better.
The selection was made around the bandwidth and slew rate (not too far from the original) but with lower noise and lower Icc opamps to avoid instabilities.
I want to try out the other more modern ones at the bottom of the list, but they come in SMD parts, so I have to adapt them to PDIP package first.
Nice work with these beautiful POAs...![]()
,Nice! Enjoy the vacation.I'm leaving on a 2 week vacation a week from tomorrow. When I get back I'll be making a large Mouser order and will include some of those OPA1642's.
James
That OPA1602 is a NICE opamp!I just looked, I still have a couple of OPA2107AP.
Also OPA2132P, OPA2134PA, OPA1602AIDR and OPA1612AID and of course LME49720 and LME49860MAX/NOPB.
James
I haven't used any of these ones yet. But I put a couple of the OPA1612 in my CD-S2000 and they are sweet!That OPA1602 is a NICE opamp!
,Here is a different question for you.It's an elegant design. I'm more repairman minded then design & analysis. It's been 30 years since I went to op amp school. But I do remember their feedback loops are crucial for gain & stability.
Fellow mechanic point of view...Don't connect your battery backwards, lol. Bad things happen. Polarized caps are like batteries.Those 3 polarized caps we're talking about are designed to be a one way street for DC. They block DC and pass AC. Notice the anodes of those 3 are tied to the positive source, +15v & +1.8. The cathodes are tied to the negative source. -15v & -1.8. I think the NP Wima's are cancelling the feedback loops to the op amp.
,How dare you... LOLI got paranoid now and went back and returned C547 and 591 to 10µF/50v elcos, I ran out of FR so used Panasonic FC. The Wimas are out of there and are now only installed in 3 positions that originally had BP elcos.
James
,Yo. I think all caps in question are supply filters.Here is a different question for you.
I'm sitting here looking at the schematic for the thousandth time.
It looks like C218, 219 (220µF) are doing local filtering/resivour for the +/-15v supply lines for the op-amps. Yes/no? That should help keep them stable, no?
So I go over and look at C524 & 525 and ask, what are they doing?
I mean, yeah, I see that C525 is directly between the +/-15v lines, and between the op-amps. and C524 is between the +/-1.8v supply that looks like it is going to the base(s) of the pre-drivers.
So they are doing local stabilizing? But why such a small value elco? Is that a case of the book keeping dept saying "That is enough and not one cent more", or the engineering dept saying "This is the exact value needed, not more or less"? Or what?
So, I'm kinda asking, what happens if some dumbass were to put say, a couple of 10µF/50v FR elcos there?
Is the law of unforeseen and unintended consequences going to come down and cut the head off of my snake?
James
