It has everything to do with the 44.1 sample rate in the Redbook standard. You must use a severe filter to prevent gross distortion in the audible band. You still get time domain errors.OK. As I see this it has nothing to do with Redbook but digital filters in CDPs and data is from forum posts and manufacturer materials.
You are mistaken. Most of what is recorded is captured at higher resolution. I would agree, however, that the number of high rez releases is comparatively limited - but growing.You do realize very very very very very very little music has been recorded on anything beyond 16/44.1.
That statement is not supported by fact and is easily dispelled by viewing a spectrum analysis of the recording. It is true, however there are some "so called hi-rez" recordings that barely exceed the bandwidth of 20k.What you buy as Hi-Res is upsampled Redbook.
Perfect to you. Not others.In recording studios 16/44.1 is considered Hi-Res. ECM, DECCA, DG all are focused around 16/44.1 and their editions sound perfect.
The audible results are blurring of detail and lack of extension. A cymbal or a bell tree never sounds live.You find sharpness and ringing in 16/44.1?
Sure. As for bit depth, you only get 16 bits at high level. Vinyl and Redbook each have their strengths and weaknesses. I'll repeat what I said in the previous post. I find that hi-rez digital combines the best of both worlds.Do you realize the artifacts that are accompanied with tape and vinyl? And how lower resolution it is than 16 bits?
Have you ever heard a CD with high frequency percussive content that sounds identical to a live, unamplified experience? I sure haven't!I hear no sharpness or ringing on a good CDP playing a well mastered CD.I must not be blessed with the golden ears.
