Never in 44 years of servicing electronics used, or felt the need to build one, and until I started lurking here over 3 years ago, and finally joining this site a year later, I never even heard of, nor knew any technicians I worked with, or met, who mentioned, or used one.
Not saying DIM`s have no benefit, or value, just turned out, one wasn`t needed in my equipment servicing needs/procedures..
A device that I built, in the late eighties, was in a sense similar, and was to take fairly high in secondary output voltage with a center tap, surplus power transformer connected to a high voltage/current bridge rectifier, two surplus computer grade beer can sized capacitors, and feed those bi-polar outputs through snap in fuse holders that I installed 6/8/12volt fuse lamps for glow observation when connecting this 100 volt DC max power supply to an multi- transistor power amp output section removed, and or electrically disconnected from the chassis, if not removable, for checking it out for shorts, before, and after any rework..
All parts mounted on a 1`X1` scrap board with a secured old scrap rack handle to carry it. from bench to bench, as needed.
I plugged it`s fused 120volt power cord into my variac, and slowly raised the line voltage feeding it, while watching the variac`s amp meter, and the fuse lamps as I raised the power supply`s output +/- voltage, and could easily find any voltage sensitive leaking outputs by feeling them getting warm at well below their operational voltage ratings, or any TO3 style transistor mounting insulation failures/compromise`s ..
It was very handy for reducing the time for checking out all the stressed out/abused rack mount high wattage PA power amps brought to me, by local rock bands, for a quicker turn around, as they usually didn`t have spare backup power amps.
Go with whatever your comfortable with..
Kind regards, Billy Ferris
