Pio1980
AK Member
Just finishing the design now.
I will be very interested how this one does compared to your original .
I have gone ahead and ordered the Phonoclone kit. Will I need to order all the items that are listed on the Mouser BOM to complete it, or is the list going to vary considerably to complete a battery supply powered setup?
I etched the PCB and already soldered a few components that I had on hand, the rest are on order from Mouser and will be here next week.
It's still 3" X 4" but fingers crossed it works well. I put the 0.1uf ceramic caps on the supply rails as close as I can get them to the op amp voltage inputs.
The main thing is I am putting these in for R1 & R2 so the resistors can be changed out quickly, no soldering, it will make it much easier when changing carts and adjusting the gain.
I had these with the Chinese line preamp kits, check tightness occasionally after assembly. I'd use micro-pin sockets instead as spring pressure maintains contact integrity.
Thanks fellas, I won't fool with it then. I was just a bit surprised since I hadn't noticed it at all prior to the installation of the IC sockets. But as I said it is so low as to be negligable. I haven't added the sockets at R2 so far.
If you want to get rid of it you can put in some 100pf caps across the input RCA's, like Steve was talking about, it would have little if any affect on the response of the cart, but I would only do that if it's annoying you.
I wonder if the poorly shielded OEM interconnects coming from my QL-A75 could have anything to do with it? It's long overdue for a upgrade anyway. Perhaps I should order a pair of those panel mount RCAs along with the 100pf's and fix it properly.
