MannyE
Exterminate!
Can you elaborate on this
I think he means that if your speakers don't go low enough, they are not speakers, but trash. Garbage to be thrown away and spit on. And I think he's joking, like i am.
You say your happy with those big K's but that it's just not going to happen in that room. So close but yet so far. Well, then you got my sympathy. And to make matters worse I agree with MarZutra in post # 16Not many options in current place .
Well unless I get a divorce I will have to buy a sub . Might as well get some rears too and get a 5.1
The klh sound great and for sure wouldn' need a sub if I was able to run them too alongside the bose but I'm just not able too right now
I think I agree where as with a good full range speaker the range tends to be very wide - full - especially with quality full range speakers for two channel listening.
My main speakers go down to comparable Hz levels as most subs. I believe 22Hz. When I was into HT, I ran two PS1200 by Paradigm. I had the full 7.2 Denon/Paradigm set up. Let me tell ya, with movies, subs are a MUST....especially 2.
Yes but they have huge cabinets? They weigh around 80 pounds each . How can you be sure yours hit 22hzI agree here especially when looking at speakers designed especially for HT which usually are rated 20Hz-20KHz. Most certainly won't reach the 20Hz - thus the addition of subs. My Epi are truly 'full range' in the most accurate description as the 22Hz is probably spot on the money with the low end. These things dig very DEEP.....
Really. You'd think a massive 80 pound 4 foot speaker with 15 inch woofers would be able to produce some low bassI agree with the other posters saying that those KLH aren't going to hit 20hz. Simply because I can tell by looking at the drivers that they don't have the kind of xmax necessary to do 20hz at any kind of volume.
That said, for me the other big reason to get a sub is that setup properly, they don't just add extension they reduce distortion and improve your overall power handling. By handing the most difficult to reproduce low frequencies over to a driver/amplifier dedicated to the task, your main speakers/amplifiers can play at the same spl with less strain and distortion.
Probably less important with a big three way, but with a two way main speaker and especially one with a smaller main driver (5-8") you can see dramatic improvement in midrange performance by getting the bass out of there.
His first post said the K's went plenty low for him. No need to buy the right stuff when he's happy with all the wrong stuff, except he can't keep them in the room.I agree with the other posters saying that those KLH aren't going to hit 20hz. Simply because I can tell by looking at the drivers that they don't have the kind of xmax necessary to do 20hz at any kind of volume.
Your asking the right questions, Your going to be happy in the end. Keep asking till you get the info you can understand and use.Really. You'd think a massive 80 pound 4 foot speaker with 15 inch woofers would be able to produce some low bass
