Stack
It's definitely the kind of project that's up my alley, and if I happened into a Dual 1229 for cheap I'd probably figure it out and embrace it... but I'm juggling so many projects (including an 11 month old son) that taking on something so complicated right now isn't in the cards for me.You are most assuredly not alone. The Dual 1229 I refer to as a "mechanical marvel" has equally been called a "mechanical nightmare". The fact that Germany produced some of the highest-quality turn tables available at the time, doesn't take away from the fact that these 1200 series record changers were tremendously over-engineered. They were complex and enigmatic machines, requiring many adjustments, lubrication, and replacement parts to keep them operable over the years. This also required an inordinate amount of technical expertise to accomplish. Without proper lubrication, the plastic portion of the "single/multi" VTA mechanism would break, and the motor and drive gears would eventually seize. The anti-skate wheel inevitably cracks and needs replacement. The "steuerpimpel" (it's a Dual thing) must be replaced occasionally to enable the horizontal movement of the tonearm and the accurate positioning of the automatic record start/end feature. Everything else will also require occasional maintenance to allow the record changer to reliably drop records, the platter to spin at the selected speeds, and the smooth movement of the highly complex collection of gears, levers, cogs, and bearings. But, as strange as it sounds, it's all worth it if you can do it. The Dual 229 has been the only record changer I've owned or worked on, during the last 6+ decades that I would trust to stack records (excluding the brittle 78s) from my extensive and expensive record collection. It also has one of the longest straight tonearms of any turntable or record changer and uses a tonearm head for a standard 1/2" stylus cartridge, either conical or elliptical. The 1229 is a high-quality and versatile three-speed automatic turntable that just happens to include an equally high-quality, well-engineered, and safe record changer.
Any opinions on the Miracords? I haven't had any issues with my 50H so far, except failure to drop the occasional very off-balance (dynaflex) disc or new records which failed to clean the sprue out of the spindle hole (fixed with a deburring tool.) That Miracord was a recent project to get working, and about my comfort level right now.
