Chip2020
Many people (mostly younger ones) think that stacking records will damage their precious vinyl collections, but this is not necessarily true. I'm an audio engineer, who's been using record changers for 60 years and I can unequivocally tell you that if you own a proper changer, your vinyl records are totally safe. Of course, older 78 RPM records made of shellac are a different story. My extensive and well-played record collection is pristine.
Almost any stereo record changer manufactured after 1958, that doesn't mechanically man-handle the records (sliding, tilting, or using blades) will not harm your records one iota. Most changers made in the '60s and '70s, using a balance arm or an umbrella type spindle, fit this bill. This web site contains an excellent chart, listing which record changers are safe to use: https://midimagic.sgc-hosting.com/safchang.htm. It also explains and debunks many myths about how record changers could damage your records.
That being said, finding a record changer that doesn't damage your records, is only the beginning if you want to find one that can do justice to your vinyl collection. You'll probably want one that sounds great as well.
Over the years, I've owned hundreds of record changers. Some were better at handling the records and others were better at playing them, but only a few could do both well. One of my favorite record changers of all time, is the Dual 1219/1229
record changer. It was manufactured in Germany during the early '70s and the build quality was exceptional. I think it represents the peak of record changer technology. In the years following this model, record changers suffered a slow transformation into nothing more than a cheap novelty, before they finally disappeared entirely.
The Dual 1229 has a heavy, 12" platter that weighs almost 7 lbs. It's driven by a synchronous/continuous-pole motor with an idler wheel. Any modern 1/2" cartridge can be attached to its headshell via a removable slide with tracking force adjustable down to <1g. When the "multiplay" mode is selected, the entire tonearm raises up to accommodate up to 6 stacked records. This, along with an extremely long tonearm (about 9" from pivot to stylus), mitigates any significant change in VTA (<5°) when multiple records are stacked.
The point is simple, there are many vintage record changers that can handle your delicate vinyl treasures without damaging them in the least, and a few of them are serious, high-quality turntables as well. You just have to find them. Constantly handling individual vinyl records (putting each one on the turntable, flipping it over, then taking it off to put another one on), will put your records at greater risk of damage than stacking them ever would. Owning a quality, well adjusted and maintained record changer, but being afraid to stack records on it, is a sacrilege and unless you really need the exercise, there's no other feasible way to play 7" 45's.
