CitrusCoyote
im a little late to ask but i ended up getting the same kit and while this thread has solved like 90% of my problems i am curious what you did with the middle input wire on the transformer-- the yellow/green oneHi bg62!
Your comments are well taken! Also, your pictorial is right on! I've already tested the transformer and wired it the way you said about tying the red and black together. The seller sent me an additional picture of the transformer wiring. It was as a document, so I converted it to a JPG to be able to attach it here.
Concerning the third-wire ground, I was wondering the same thing! The transformer comes with a ground wire as part of the primary winding, yet it doesn't appear to be used! If you look at the picture showing the transformer mounted into the chassis, you can follow the path of this ground wire as it is wound around the high-voltage secondary wires...and appears to go nowhere!
I've also attached a picture of the IAC connector, which has a 2a built-in fuse. I've color coded the connectors...Red for "hot" and Black for "neutral". While the schematic shows that the ground lug isn't used, it would almost appear that the picture shows a neutral black wire connected to it. That doesn't make sense! So, yes, I'd also be interested to hear what the AK community has to say about this!
Forgot to mention this...the blue wire attached to the IAC is the "hot" (the kit comes with a large length of blue wire) and goes back to the power switch. It's interesting how the picture shows the way it's looped around all the other wires back to the switch!
im genuinely clueless where it goes or what to use it for since i cant find any connectivity between it and anything else
