Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Throwing this out there.... any Dual peeps that would know where I can get a replacement strobe pattern to glue to the bottom of the Dual 701 platter? Could I print it from a file?
I took the yellowing peeling strobe card from the bottom of my 1229 platter to a print shop with those fancy commercial zerox's and online editing capabilities and had a graphics designer scan, edit, enhance and print me a new strobe card on his recommended chrome paper. I then cut it out of the print using a rotary compass circle cutter and used some drops of contact cement to glue it back in place. I could probably print it at home but I needed a pro to consult. It turned out better than the worn out original.
