Re: dodog,
- Yep, they are over 100lbs each at this point
- The corner braces really only affect the area they cover, leaving an unbraced smaller panel between them (between two of them on opposite ends of a panel, the long way, I mean). There are more effective ways to go, but I was running out of room.
- The insulation is glued on with 3M 77, although in some places where work needs to be done it is just tucked in for now. The piece around the cross brace is tied on with hemp twine
. It is treated for fire resistance, but my crossovers are staying external so that's not something I considered.
- Sure, the wrong way to add insulation is the way that screws something up
. I'm not going to pretend I'm in a position to say much more about that. I will be trying to investigate bass response further, but it does not seem like it was affected by these changes and if that is the case, I think all of this insulation can only be good in these speakers.
- As far as I'm concerned, yes it is normal to insulate the waveguide. There is certainly no advantage to sound from the woofer passing through it, nor reflecting off it.
