Dynaco A10 Speakers ?
My Pioneer SA-610 amp is only rated for 6ohms, so it says on the back of it.. :scratch2:
You are correct, there is a warning on the back of your Amp, 8ohm-6ohm or greater, something like that.
This is a warning to only connect speakers rated at 6 ohm or greater, which is still very good for a small Amp
I've made a mistake with the SA-600, and even that, the 600 is rated at 50w at 4ohm and not 60w as I said before.
Should get my facts straight before I open my keyboard.:D
I had one of those multicolor caps (same exact colors/size) in my Rectilinears, and they measured 2.2 uF.
Well this is better thanks, 2.5uf and 2.2uf does not make a big difference, as 0.00025uf would of done.
So both speakers had the same total capacitors,but still kind of strange to use different type of capacitors.
The color code is kind of strange, to me anyway, especially that my cap as the white in the third row, which does not add up too well
. Here are a couple of color code charts.
http://www.diystompboxes.com/smfforum/index.php?topic=58335.0
http://www.electrojumble.org/colour.htm
http://wiki.xtronics.com/index.php/Capacitor_Codes
Nice little speakers -- sound and look good! Have a pair in storage still; haven't used them in ages, but they were too cool to get rid of, so I've kept them. Recommended if you find some.
As unlikely as it would seem, I bought both of mine as orphans to make the pair. :)
Rob, if you are wondering if a small, 20w to 40w amp, will drive the A-10, my answer is yes.
The Dynaco are quite stable, they don't have any exaggerated dip. The A-25 goes from an 8ohm to just slightly below 7ohm.
All other are also very similar, from the 10 to the 50
I am driving mine with a Harmon Kardon 330A rated at 17w per channel and it’s just perfect with the A10s. I have removed the tweeter metal grills which I think has made a huge difference to the HF dispersion. I love the combo. PS I added an Ortofon Red cartridge to the TT and that improved the clarity and brightness without losing that classic vintage warmth.
Hi Rob,
As typesix stated, frequency from 50hz to 15000hz
Also, all Dynaco has an 8ohm impedance.
The efficiency should be better than 88db, I would say 88 to 90db. I realize this is not too accurate as a 1 or a 2 db, makes a lot of difference. It is hard to get info on efficiency on the Dynaco line. Dynaco did'nt make too many tests on their speakers like Acoustic Research or KLH for instance.
So as far as efficiency, this is only a guess on my part, a good one, but still only a guess.
