That is in the picture. My recommendation in my first post should maybe mention that the bias test should beThe risk with removing output stage tubes, and then powering up, is that the filter caps and coupling caps may well be exposed to noticeably higher voltages than those caps are rated for. That can be exacerbated by having a modern-day higher mains AC voltage than the vintage amp was nominally set up for. The main filter caps may also need a soft start to allow reforming and lower the initial leakage current to a survivable level. It is not unheard of for a bad main filter cap to take out the power transformer and/or the rectifier tube. Likewise the rectifier tube could be gassy and start arcing and it is not unheard of for that to then take out the power transformer.
brief ( less then 15 seconds). That's also why i mentioned to measure the remaining voltage on the B+, if
it's still around 200V then the cap is not fatally broken.
