trobbins
A 430V secondary could give up to 600V for a few seconds for 117V mains with a GZ34 (as the capacitance is low, and the signal valves often take a few secs longer before starting to load B+, and there may be no other loads until then, and the transformer may provide more than 430-0-430 with no load). At the moment I don't think you know what your mains voltage is ? So I'd suggest a 600V surge may not be sufficient margin. Normal modern capacitor rating has a +10% surge spec (ie. 605V for a 550V nominal), so if they say surge is only 600V then maybe there is little tolerance above 600V.
