Donstaff
Trobbins,
If the bucking or autotranformer means one of the $10 range filament transformer, it is not beyond my price scale. I am s new to this that I am still having trouble sorting out which would be the best way to go. Whether there is a best course, or are there two courses that can both be used.
On the one hand, the autotranformer seems to be the way to solve the line voltage issue between Dynaco's original 117 vac design and my 125 vac mains. It stands to reason that that extra voltage is harmful to the circuit.
On the other hand, using Retrovert's suggestion of using a timer like the 555 (bistable with an RC constant) to trigger a solid-state relay (AC relay using a TRIAC, SCR, or something similar) could be used to switch out a resistor used to temporarily limit the level of the turn-on voltage surge. I already have a new quad capacitor (30-20-20-20mf, 550 vac - 600 surge) for the Mark III.
I'm willing to use all of these, but I don't fully understand how to wire everything. That is why a sketch would be so helpful.
