davesnothome
So an update on my progress, I removed all ground connections and will have them resoldered tomorrow. Should have new plate resistors in on m Monday. Just received the shorting caps on the mail today so I'm hoping tomorrow I can rule out the ground connections and can test each input with the shorting caps. I checked all soldered connections on the power supply board and they look good. Looking over the Erhard photos that were posted and will validate those tomorrow as well. Hopefully this will help narrow down the cause. I can't thank all of you enough for the help on this. I've never worked on a PAS before so this has been a crash course and I can't thank this community enough. More to come as I work through this. Not an electrical engineer so it's probably taking me longer than those who have experience with this but thank you again for the direction.I think B+ is connected to the board via grommets also. The circuit board under the selector switch can be ignored, that is the mag phono board, and the OP said it occurs on all input settings, as well as when the power supply is turned off for 15 or 20 seconds. So, concentrate on the board that is parallel to the front, that's the voltage amplifier that's causing your problem.
