Would tend to agree with Peter, only caveat to that is, not knowing all the possible changes that have been introduced over the years, both parts, and possibly mistakes....
Out of curiosity, how is that Alps volume control grounded?
If you don’t have the ability to check the signal path, you could do things like, bypass the balance control, disconnect the phono board, and/or disconnect one channel at a time etc, and note if there’s any changes after each.
For instance, it would be simple to bypass the stereo/mono switch, and see if that changes anything....
I’m about to start working on a PAS in which I’ll also install the Erhard power control, just not sure what all has been changed on it either, but it does have original boards.
Haven’t really looked at it very closely yet, It will be interesting to see how it turns out....
Not sure any of the above will help, I’m just sorta thinking out loud, may not be prudent to listen (-;
Andy
