Dynaco Pat-4 resistor ratings
eizner23
Are all the resistors in this unit 1/4 watt, other than the 3w resistor noted in the pat-4 assembly manual? The manual doesn't note ratings.
All of the original resistors were carbon composition resistors rated at 1/2 watt. Any resistor on the PCB's could be replaced by 1/4W metal film, with the exception of R20's, the big 620 Ohm collector resistors. There are also a few exceptions in the power supply Here's the parts list fo the PCB's (mostly):
You can also download the manual here:
http://updatemydynaco.com/pat4.html
