shelby1420
Enjoying the music.....
Hi Dave, yup the other mod worked wonderfully, thank you!!!!
I tried to do the adjustment as stipulated in the manual, however the hum is so bad I cannot get the volume past 11 on the dial without having to leave the room, it is that bad..........
I will check the wiring, brown and yellow tonight
I have tried the plug turning to no avail
swapped out 3 sets of 12ax7 and two sets of 5751
I will try the test you have suggested in point 6 in a bit, thanks a ton for all this information Dave!!!!:thmbsp:
Ok checked the wiring, on this unit two tubes closest to the selector switch there are no wires coming from pins 2 or 7 ( there resistors from both and a jumper wire from pin 2 to a tag board, see pic....)
If I am seeing things correctly the little black cap and the shinny blue ones are the caps you mention in point 4, yes?
I did the test and when I turned off the hf 85 the hum went away immediately!!!
