Eico's Owner Group
Long time EICO fan here. I have a pair of what started out as HF-22 monoblocks, but I changed the power transformers to run EL-34 outputs effectively making them HF-35s. I also changed them to fixed bias so they are now more similar to HF-50 but with the HF-22/35 output transformers. In each of these configurations, the EICOs have sounded very nice and easily competitive with modern gear.
I also have a pair of HF-12 integrates where I removed all of the preamp circuitry making them equivalent to HF-14 power amps.
Lastly I have a single HF-20.
I came to EICO initially because of the circuit design, the quality output transformers, and the ease for making modifications. At the time I considered the homely appearance just something I had to tolerate, but that attitude changed over the years. I now like the brown color and no-nonsense appearance very much. It is a true "form follow function" design and has a refreshing honesty in today's world of bling.
salectric,
My 3rd HF12 is waiting for my soldering iron.
turning it into a power only amp sounds intreguing.
Did you just cut all connections to the pre section making it just pwr, or
was it more involved than that? I'd really like to know.
I too like the old funky Eico look altho so far I have changed color on my Eicos to duplicolor auto met red.
brightens em up abit. But next Im gonna try for something closer to orig brown.
When I converted my HF-12 integrateds to power amps, I disconnected and removed all of the preamp circuitry and controls. What is left is literally the HF-14 power amp circuitry. I also added a fuse and power switch. I can't believe EICO released an amp without any protective fusing. Of course the Dyna PAS doesn't have a fuse either.
sounds easy enuf , atho l mite just remove the phono circuitry
and keep the rest. but who knows. a nice future project.
thanks.
I removed all the linestage and control circuitry because I didn't like the idea of all those unnecessary parts possibly affecting the sound. The amp itself is about as simple as you can get for a push pull design.
yeah I know. I mite do the same.
I'll see how I feel about it when I heat up the soldering iron.
They are pretty good sounding little amps .
I really like their simplicity. tru for the other Eico stuff I have.
Did you notice any improvement in sound with just the pwr amp?
It's been too many years since I modified the HF-12's for me to recall what changed. Unfortunately I haven't used any of my EICOs in the last 8 years. As much as I like each of them, I have other amps that I like even more. Maybe these posts will motivate me to pull out the EICOs again.
Steve are you going to pick your own parts, or get a rebuild kit?
I will probably do some research, and pick a few brains before ordering anything. Id like to update things like going with just 8 and 4 ohm modern binding posts, and whatever helps it be at its best when finished. If I can get someone to silkscreen new lettering I would like to bring the chassis back with a nice paint job.
Remember when someone post in AK, anywhere, on AK, the Googler will find it. That is one of the problems with the Yahoo forum club. It is in ninja mode. Packard Bell,Eico, easy to find in the tube section.
I have requested that we start an Eico Forum here on AK. I first got a reply from someone who referred me to Grumpy, the site owner. He said he will get back to me soon.
I am willing to be the moderator, but would rather not. I have a small business with my son restoring vintage Sansui gear, it would kinda be a conflict. If someone here wanted to be the moderator, that would be great.
Over on the Yahoo group, we've been talking about it for a while. No consensus at all. I think that a group of us should just set it up, if AK will let us, and then the migration would most likely occur. I'd hate to wake up one day and find the Yahoo newsgroups no longer functioning. Yahoo is not doing well as a company.
this Eico sticky will doo just fine I think.
But if you want to fight for a forum go rite ahead.
good luck.
many of us will support U.
good luck.
I don't understand why it would be a fight or difficult? o_O There are already a lot of Eico postings here on the tube forum, and Eico was a major brand. Van Alstine has a forum here, and check out the number of postings on that. It seems to me that most of the folks on the Yahoo group want to go, so why not?
