El34 / 12AX7 SE Build (My 1st build)
you could leaving the triode/pentode resistor out of the circuit when running in triode ( no feedback) the 360k is the feedback resistor. Just leave the feedback open.
most triode amps require no feedback.
True. The 360k is feedback for UL mode only. In triode mode, zero feedback would produce the most distortion. But it would be fun to play with the triode feedback as-well. I view feedback values as a way of 'voicing' the amp.
I would expect open loop to be louder for the same signal, but switching to triode mode could have less gain so curious how that ends up. You might also notice a bigger difference in the open-loop-triode-mode sound as you crank the volume up- as you approach maximum power the distortion increases significantly, and can, from what I have heard and experienced running pentode amps open-loop, give a sort of "bloated" sound.
I did a quick db measurement using my trusty 30 y/o Radio Shack decible meter. I set up using one channel only at 1 meter and 500Hz signal. The open loop triode mode measured +3db compared to UL mode. And with the 750k in the triode loop, it dropped to +2db compared to UL mode. I couldn't play around much further due to complaining females and dogs presently in the home. :(
Correct and if it sounds a little on the bright side with no feedback and the 750K sounds too dull, try a 1meg etc. I highly doubt you hurt anything, even that tube is probably fine.
Just a quick update. After some critical listening, I like UL better than triode. UL to me just sounded better balanced throughout the full range. Triode with zero feedback especially was very bloated in the midrange. If I do any future builds, I will skip the UL/Triode toggle caapability. I also preferred the 5751 over the 12AX7.
Good news is my Analog Discovery 3 will be delivered soon.
It's fun to experiment but yeah, that's why I don't put that switch on my for sale amps and also why I supply a 5751 tube :) Glad to hear your ears agree with mine. Did you play with different feedback resistors? With that switch you could wire it to AB listen without having to break out the soldering iron between sessions.
Just a quick update. After some critical listening, I like UL better than triode. UL to me just sounded better balanced throughout the full range. Triode with zero feedback especially was very bloated in the midrange. If I do any future builds, I will skip the UL/Triode toggle capability. I also preferred the 5751 over the 12AX7.
This is so much a subjective personal thing- I understand people gravitate to tube amps because they are looking for something that sounds different, decrying the "sterile" technical accuracy of modern solid state amplifiers. There are so many ways to make an amplifier sound different, by intentionally introducing different mixes of distortion and harmonic content (error) into an otherwise accurate reproduction. It is humorous to me those who enjoy introducing distortion in this way would poo-poo any sort of signal processing, filters, sound effects and the like that could apply similar distortions as being somehow impure or gimmick. Driving an amplifier design to have intentional distortion is very much a guitar-world approach- I have seen so many tube circuit tortured into producing just the right sound, and "tuning" a high fidelity amplifier based only upon how it sounds is perfectly valid in that world, but just does not make sense to me in high fidelity. Whether tube, or silicon, I would expect an amp to be as wide and flat as possible, with as little distortion as achievable, and in such case, a tube amp will still manage to sound different than a silicon amp, but still present an accurate reproduction of the input.
In the amps that I have built, pretty much SE or PP pentodes in pentode mode with global negative feedback, I really don't play with ultra-linear or triode mode because using high open-loop gain and global negative feedback is SO much more accurate. The global negative feedback resistor sets the amount of feedback, which does affect tone somewhat, but much more so overall gain. The capacitor parallel the feedback resistor sets the frequency compensation, which effects the flatness of output across frequency. When tuning the frequency compensation of global negative feedback, there is seemingly only one valid "correct" amount of compensation- that which results in the flattest frequency response across the widest extent possible, and provides the best transient stability.
In my "Mirror Mite" project, a 6AQ5 (7-pin 6V6) push-pull amplifier, I took some compelling data on frequency response per compensation capacitor value shown in the chart below. This is at a very low power level so limitations of output transformer saturation at the low end, and winding capacitance/inductance "slew rate limiting" at the high end are not the limiting factors- The open loop (no feedback) result is in blue- roughly 50Hz to roughly 15kHz at 1dB down. Applying =any= feedback, compensated or not, dramatically improved the low end- now reproducing down to 15Hz at 1dB down. Frequency compensation only affects the upper end- and the amount of compensation dramatically alters the reproduction.
With negative feedback, but no compensation, this exposes a downside of any feedback in that it allows the input of the amplifier to now see bad behaviors of the output transformer and amplify them. The result is that the resonant frequency of the output transformer (this is a value transformer) dominates from 20kHz to 60kHz causing a huge spike (in orange) in output amplitude that was not there in open loop. Not only can this cause oscillation in the amplifier, but it has an unpleasant effect even on audible frequencies by exaggerating transient response. (This is shown and discussed more in the images below the chart). However, this can be corrected by adding compensation capacitance, and with different amounts of cap that resonant peak is brought down to the green line at 1650pF. That compensated response is not only correcting for the bad behavior, it is now providing a flat response all the way out to 60kHz, dramatically better than achievable without feedback. Its hard to reason that any other value of this cap would be correct. While I would never hear that, it does have dramatic effect upon transient response and overall accuracy of audible frequencies.
The two images below show transient output response for a 10kHz square wave input at low power levels. Uncompensated feedback shown on the left, where output transformer ringing causes exaggerated response to any and all transients, and while 60kHz ring is not audible, it does create audible error in reproduction. With proper feedback compensation shown on the right, the amplifier is now critically damped, meaning that there is a brief overshoot, but it is brought back under control very quickly and the audible 10kHz square wave is more faithfully reproduced.
It is interesting to compare the transient response with compensated feedback above to the open-loop (no feedback) response shown below for the same amplifier. With no feedback, the input does not see the output transformer resonance, so it reproduces the 10kHz square wave beautifully, at least in terms of there being absolutely no overshoot or ringing. (just as the blue response in the chart above has no resonant spike at higher frequencies.) Note however, the result of the rapid frequency roll-off above 10kHz- the amplifier is becoming a low pass filter, rounding off the edges of the square wave by attenuating all of the higher frequencies required to reproduce the square edges. The rise and fall edge rate is quite slow, meaning it will have more difficulty giving crisp edges to transients in the music. Now, things become philosophical- what is better? The very smooth, rounded reproduction of open loop, meaning you will not be hearing much content above 10kHz, or the more technically precise representation of the square wave above with more overshoot? There are a lot of factors to consider- The very much better bass response could be compelling, but my output transformer is so small it would saturate at higher power levels and never deliver the 15Hz promise seen at very low power, so maybe it does not matter. The very much better high frequency response from 10kHz all the way to 60kHz seems appealing, but I probably could not hear it. Great arguments can be made for either side, but I will attest running open loop does sound very good (to my old ears at least). I ran this amplifier open loop for a good while, and it was only the fact that the sound fell apart at higher volumes that I decided that compensated feedback was the only way to go. It is now apparent that from sound quality at lower levels alone, there will be fans of either approach.
I am going through all of this to think out loud, but also to indicate that the Analog Discovery will enable you to have more tools to observe and understand what impact the modes of feedback, and to what degree, and what compensation have on the actual behavior of the amplifier, and ultimately the accuracy of reproduction. When you have this increased visibility, you will no longer have to choose or tune feedback based only upon how it sounds. Perhaps this is interesting to you, and perhaps not- I don't disagree that in the end, all that matters is how much you enjoy the amplifier. For me personally, and my engineering background, I enjoy knowing that what I have built has technical merit beyond just sounding good, and that adds to my overall enjoyment, be it placebo or not.
But then you go into the "listening for what sounds best" phase with a bias of a strictly engineering perspective. Many times what sounds best in the room with a specific set of speakers is not what measures best, but if you go into it already knowing what tests best... But yeah I understand that many engineers seem to only care about what the measurements show.
BTW I personally think push pull high gain/high negative feedback amps sound sterile and very close to a solid state amp, at that point I wonder why ever bother with tubes if that is the sound you are after. I'd much rather listen to a zero feedback DHT SE amp.
Most tube feedback amps, especially push pull, will benefit from lead & lag (also called a step-network) compensation. Both compensation networks should be applied to yield a flat frequency response, wide bandwidth and good stability However, distortion at 20kHz should also be checked (iteratively) to ensure you have not lopped off too much gain at high frequencies where distortion can easily rise if compensated too much.
Overall, I agree with you above assessment, but you will find a lot of people here just don't buy it and will build their amps and just listen to them, which is what they are for.
It's like black & white TV versus Color TV... I guess those old westerns just would not be the same in color.
Yes! It will be a big part of my learning journey.
I totally agree. Knowing the measurements that go along with a good experience would have much value IMO.
This little amp is getting some good testing. Critical listening for now and then on the Analog Discovery 3 when I get it mastered. The tube rolling has been interesting but now for some speaker rolling. How about a pair of $27,000 Kef Blade 2 Metas to help her shine? OMG! Kinda reminds me of $10k wheels and tires on a 1966 ghetto Cadillac. :rockon:
I'm loving my AT33 Mono cartridge and am building a collection of mono vinyl. Those old jazz recording never sounded this good on the stereo versions to me. Same with shooting film cameras, never use anything but black and white film :) And yeah I still shoot with film too.
But please listen to them first. You might be surprised what a "good sounding" amp measures.
Real photographers still use film... b&w or color. I agree.
I dabble in astrophotography, and use an older D5100.
One of my diy cameras. A modified 6x9 Mamiya Press. Pure analog.
Since you like DIY cameras, have you ever tried pinhole with medium format?
In college I ripped the bellows and lens off of a crappy 120 6X9 folding camera body, and replaced it with a shallow cardboard box with tinfoil pinhole, only about 1-1/4" away from the film so it had a really wide field of view. It took some trials to get just the right pinhole free of burrs so it would cover the whole frame, had no viewfinder so it was "aim and hope" and with 400 Tri-X the exposures were a minute or so using a piece of electrical tape for a shutter.
Now in my older years, I'm really loving how my negative scanner and software have eliminated the entire darkroom/printing hassle. So easy now to use a dark bag and develop film at the kitchen sink and do spectacular images so quickly. I've been scanning in all of my old negatives and prints.
I am totally stumped. The amp has been playing quite a bit and sounds really good. My new Analog Discovery 3 is up and running BUT something is screwy. The amp is in terrible condidtion, OR the new Discovery is flawed OR the Audio Analyzer software is not compatable with the new Discovery 3. I was only able to run one scan. When attempting other scans, I get prompted that the distortion is over 25%. The scope won't even give me sine or square wave. Here are some screen captures:
@John Berard - try starting your sweeps at 30 Hz instead of 20 Hz. That might get you out of the 25%+ distortion range. If that doesn't work, keep bumping up the Hz to 31, 32, 33, etc. until you can get the sweeps.
Something definitely looks wrong with the blue channel. Try running the sweeps only on the red channel.
OK if you can't get sine waves on the scope, something about the setup is wrong. I would focus on getting that to work first! Make sure for example the probes aren't set on 10X etc. And you are using dummy loads right? I know those are dumb questions, but other folks have made these mistakes, I've done the 10X probe one myself :)
I run most of my sweeps at 1Khz as that is the "industry standard". The fact they aren't able to get the scope function to work is pointing out a setup problem.
This is what I have tried. Tried 2 different computers with both the Diligent Waves and Audio Analizer Suite software installed. Tried 2 different amplifiers; my new build and my Dynaco ST70. I get the same results from all combinations. Even the Diligent Wave software will not give me a sine or square wave.
What is concerning is that when a 1kHz signal is sent to either amp with either computer, all transformers have an audible 1kHz tone coming from them. It will also get louder with more amplitude applied. This must not be an amp wiring or software issue. Yes, I am using an 8ohm dummy load. I think I followed all the connection instructions correctly. See below for my hookups.
I am totally baffled. This must be something stupid I am overlooking or I have a bad Analog Discovery 3.
