atmasphere
I've been having fun with EL84s recently, which started with a refurbishment of a Dynaco ST35.
I'm convinced its power level and the ease at which it can be driven make it one of the best sounding pentodes made.
After refurbishing the ST35, my next project was a Nobles Manufacturing NS-130 which might be the most elegant EL84 based amp every built. They were made in St. Paul MN during the late 1950s and early 1960s and are quite rare.
Online I saw people were messing with the RCA RS199 which is a stereo console SE power amp. Its rare and if I found one I'd be tempted to strip it to the nuts and bolts since I like things to look nice. That convinced me I might as well design one from scratch. I'm interested to see if it can compete against a 2A3 based SET.
This project is a pair of monoblocks, each making about 3.5 Watts. The power transformer is the Hammond 269EX. The output is the Edcor GXSE10-6-5K. which has an ultralinear connection.
My plan is as compact as possible. I might have to make two versions as it would be nice to have a balanced input using a differential amplifier which would also be the driver for the power tube. But right now the circuit I'm planning uses the 12AT7 sections in parallel to get as much bandwidth and Voltage swing as I can. I plan to play with feedback but will mix it on the grid of the input tube to reduce distortion, rather than the traditional means of using the cathode. That will help keep harmonic generation due to feedback to a minimum.
