It functions as feedback for the output and as a plate load for the EF86. Totally experimental in that I've not seen a circuit like that before. But it seems to work. Not put it on the bench yet to see how bad the distortion is, but it sounds pretty good anyway.
Actual plate Voltage is 266V. The screen runs slightly higher. About 9.4V on the cathode. The 250Ohm resistor was all I had laying around that was in the ball park.What B+ voltage do you have here ? It is probably "forced" by the 250R cathode resistor, to reduce plate current of the EL84, if the power of the PT is small ? I'd say circa 220-230VDC ?
Edit : OK - I saw that the 269EX is a 2x190V @71mA. Enough current, but a bit short in volts... So what are your Vp, Vs and Vk on the EL84 here ?
T
an ultrapath cap runs from cathode to B+ instead of cathode to ground.
Ultrapath was simply a way to bypass the cathode resistor without having to use a large capacitor (across the cathode resistor) which were very large and expensive in the early 20th century.an ultrapath cap runs from cathode to B+ instead of cathode to ground.
IIRC, a friend of mine, Jack Elliano, invented the Ultrapath concept.Ultrapath was simply a way to bypass the cathode resistor without having to use a large capacitor (across the cathode resistor) which were very large and expensive in the early 20th century.
Invented or popularized?IIRC, a friend of mine, Jack Elliano, invented the Ultrapath concept.
