Electrostatic Speaker Repair in the SF Bay Area?
TSmith8605
Senile Member
Does anyone know of a good place to get 20-year-old Acoustat electrostatic speakers checked / serviced in the SF Bay Area?
I do not want to ship them.
Not sure who, ,exactly, you'd have to talk to. If they were mine, I'd be on the phone to the folks at the Analog Room in San Jose. I know that there are some here who have been turned off there but they don't have their own service division _and_ they're pretty knowledgeable about who's ok in the area.
Just a thought.
Cheers,
David
Just a thought.
Cheers,
David
Good thought, thanks.
Terry,
Acoustat speakers are considered pretty bulletproof. What sort of trouble are you experiencing?
Terry,
A slight upper mid-range sharpness - I'm not sure if this is caused by the speakers or something else. This appeared when I started using McIntosh electronics, but then a whole bunch more music also appeared when I started using the McIntosh stuff. Also, no one else has reported this problem with the Mac equipment.
In any event, the speakers are twenty years old and I wanted to at least verify that they are working as well as they should and have not deteriorated somehow.
From what I understand, that once the grill cloth is removed, it is hard or impossible to reinstall it. Otherwise, I could probably just remove the covers and inspect everything.
They are probably OK.
What happens when you pull the Mc offline and sub something else in? Also, what Mc units specifically? I did not particularly care for Mc/CLS combination some years ago when I heard it. I used Mc/KLH Nines for years and it was magic.
I used to service Infinity's full range electrostatics in Atlanta. One thing that caused lower volume/arcing was dust buildup. The electrostatic attracts dust. So I vacuumed them with a low power vacuum. Once the grid arcs to the mylar, it has to be insulated with something like RTV.
IIRC there was a place that would repair electrostatic panels. But I can't find a link for them. Maybe they are not in business anymore.
Acoustat speakers have a lifetime warranty (this may be for the original owner only). My neighbor has his repaired under warranty about five years ago. Yes, shipping is a pain, but, it may be worth it if a panel needs replacement.
I lose the edginess along with a whole lot of resolution and musical content. There's no going back, I'm sticking with the Mc stuff - it is much better.
I am using at different times: C220, MC275 IV, MC2505 (DeWick), C22 (DeWick) and an Audio Research D-115 MK 2.
The issue goes away when I use my older Klyne SK-5A preamp and / or Musical Fidelity SS amp, both of which have far less resolution than the electronics listed above.
I used to service Infinity's full range in Atlanta. One thing that caused lower volume/arcing was dust buildup. The electrostatic attracts dust. So I vacuumed them with a low power vacuum. Once the grid arcs to the mylar, it has to be insulated with something like RTV.
No problems with arcing. Also, I think I remember a website, as well, and it does not work any more.
Thought they went out of business years ago. I think a Korean or Chinese company now has the brand name.
