MeatInStereo
Can outrun 80% of snakes
Well, I used the beloved putty knife to pry off the 40 year old glue holding the crossover....success! I had the choice of removing all the internal wiring of the woofers and tweeters. With six speakers in the cabinets it wouldn't be too fun. It would be possible as I did diagram the connections a couple of weeks ago. I chose to pull it out of the rear 8" speaker opening as the wires were long enough to pull it out after it was unglued. I just pulled up a TV tray and worked on it that way as the tray was the perfect height being connected to those Bose tulip 901 stands. I removed the old caps and resistors and soldered the new ones on one at a time. The biggest complaint i would say about the parts received is they are a lot bigger then the OEM caps and resistors. Looking back today i think i would have soldered jumpers to the connections and then soldered the jumpers to the caps and resistors but the inside of the speaker is busy enough.
After replacing them I connected my amp to the back of the crossover with all the speakers hooked up but out of the cabinet....basically everything is out of the cabinet haha! WOW! Do they sing...and again this is with them outside of the cabinet... simply amazing... the highs are very detailed and crisp....the mids are phenomenal and perfect....the bass is accurate and room filling. I will post the pics later. I have to work on the working speaker's crossover next.
After this I need to hit you guys up on making the wood look new again. the speakers are in great condition for being as old as they are but they need oiled up.
Many, many thanks to all of you who helped me out with this... you are truly experts and great friends to have spent the time posting diagrams... posting tips and things to try...thanks!
