Interesting, I’ll have to check I noticed the wires were slightly different colors and stifferI assume you will measure these before you install them. I am thinking that the AMT3 used to use an 8 ohm version of the diaphragm. One pair of spares I have in the old original series measure about 5.5 ohms each. I don't think anyone; ESS or simply speakers is selling anything but a 4 ohm version anymore. I don't think simply speakers lists the impediance spec. Its one size fits all. So I will be especially interested in hearing about the new ones in your 3s.
Yup. That makes sense. Its a 2 way the way as all the Great Heil systems were except the AMT3. Now there were some other ESS systems that were 3 ways, some LS series or Performance systems and/or Tempest systems that used the ring Heil or the dual plate Heil and these crossover over at a higher frequency. I don't think they are going to make a diaphragm just for the AMT3 when all others use 4 ohm and they are far more abundant.My Great Heils (from a 1D) have a dc resistance of 3.6-3.7 ohms.
SureYup. That makes sense. Its a 2 way the way as all the Great Heil systems were except the AMT3. Now there were some other ESS systems that were 3 ways, some LS series or Performance systems and/or Tempest systems that used the ring Heil or the dual plate Heil and these crossover over at a higher frequency. I don't think they are going to make a diaphragm just for the AMT3 when all others use 4 ohm and they are far more abundant.
If I remember correctly, my originals measured 3.3 ohms on the VOM.I assume you will measure these before you install them. I am thinking that the AMT3 used to use an 8 ohm version of the diaphragm. One pair of spares I have in the old original series measure about 5.5 ohms each. I don't think anyone; ESS or simply speakers is selling anything but a 4 ohm version anymore. I don't think simply speakers lists the impediance spec. Its one size fits all. So I will be especially interested in hearing about the new ones in your 3s.
The new ones matched the old ones in DC resistance.I assume you will measure these before you install them. I am thinking that the AMT3 used to use an 8 ohm version of the diaphragm. One pair of spares I have in the old original series measure about 5.5 ohms each. I don't think anyone; ESS or simply speakers is selling anything but a 4 ohm version anymore. I don't think simply speakers lists the impediance spec. Its one size fits all. So I will be especially interested in hearing about the new ones in your 3s.
Nice!The new ones matched the old ones in DC resistance.
Listening results: So far, the differences are subtle, I think my original right channel diaphragm was a little weaker than my left as the bigger difference was from the right. There's a slightly increased forward edge on the featured performer (vocalist, soloist) with the new diaphragms, but not the drastic change I was hoping for - the lead is still rearward of the rest of the band . A better sense of the hardness of the drum stick tip hitting the metal cymbal. The kid is asleep and will be getting up to go to work, so I should have some time for more critical listening later tonight.
Those 5.4 diaphragms look like my 5.4's as well.I'm selling a couple of these diaphragms to my west coast seller and getting a couple of empty Heil cores with which I'm going to cobble together a couple of add on Heil supplemental tweeters. So I had to measure all these. The old one with tripple rows of silicone is 6.7. The older pair with no silicone or bridal veil measured 5.5. A somewhat newer pair in ESS factory packaging measure 4.0 and 3.8. Even though these may be as much as 10 years old, I think they are representative of the current product.
Critical listening???The new ones matched the old ones in DC resistance.
After much more listening at the varying levels that my ears go back and forth between, I've come to the conclusion that the diaphragms were a worthy upgrade. The overall transient response on hand claps and snare drums was the first noticeable symptom. The level on both channel's Heils has increased to the point where I had to turn them down a notch. I tried tweaking the level on the Alphas, but I still prefer them at the halfway point, even with the new diaphragms.Critical listening???
View attachment 1966158 View attachment 1966159 View attachment 1966160 View attachment 1966161 View attachment 1966157
Forget biamping and active crossovers
Waste of time and money
This integrates your “other” loudspeaker, know as your room , with you actual speakers.
FIY, we still enjoy the so called ‘Great Heil’ peak... leave it alone, or your listening enjoyment will be as flat and boring as the Salt Flats of Utah!!
Appreciate your comments and assessment. I think new diaphragms are something I should consider for my older pair of 3s. Especially before the price increase filters to all suppliers.After much more listening at the varying levels that my ears go back and forth between, I've come to the conclusion that the diaphragms were a worthy upgrade. The overall transient response on hand claps and snare drums was the first noticeable symptom. The level on both channel's Heils has increased to the point where I had to turn them down a notch. I tried tweaking the level on the Alphas, but I still prefer them at the halfway point, even with the new diaphragms.
If I'd have known of this outcome, I'd have made the purchase back when I did the rebuild.
As for bi-amping, given the equipment that I'd want to do it with for free, I'd do it in a heartbeat. I've heard the AMT-1A's through a tube amp and would love to duplicate that, only with solid state oomph to the woofers. It would be the best of both worlds.
Sure-I had to put them down a notch-for a few weeks-now they are currently in the middle position.After much more listening at the varying levels that my ears go back and forth between, I've come to the conclusion that the diaphragms were a worthy upgrade. The overall transient response on hand claps and snare drums was the first noticeable symptom. The level on both channel's Heils has increased to the point where I had to turn them down a notch. I tried tweaking the level on the Alphas, but I still prefer them at the halfway point, even with the new diaphragms.
Holy cow. These 75uf Daytons are huge! Sorry automojo, I know you are not a fan of the Dayton's, but I thought I might save some space by getting a single cap as opposed to combining multiple caps. I should have looked at the specs for dimensions. Anyway, I measured both Daytons with my Fluke and got 75.1uf and 75.3uf. I purchased 10uf and 16uf Jantzen Cross-Caps for the 26uf capacitor. It will require a little creativity to mount the 75ufs.Got it!
If he is just looking a nice neutral cap a Jantzen Cross cap or Standard Z cap would be just fine more or less a refresh + I would certainly recommend these over the Dayton/Bennic poly caps.
Yep, you will figure it out- but they are giant!!View attachment 1980632 View attachment 1980633
