sbradley02
Th ESS driver should work.
I'm not all that good at wood working either.
I just thought out the brace-2 "C" shapes, and one board from side to side.
The holes were a hole saw, slightly undersized, and a sanding drum to fine tune the size-epoxy to hold them in.
I got the tubes from P.E.-closeout, and had a exhaust/muffler guy cut them for me as a favor-so they would be straight.
I will have to check- but the volume actually calculates to around 2.4 cu. ft(with mid tube/woofers)-so this is why the Dayton works well-smallish enclosures.
Thanks, please let me know what you get for volume, though as you mention there are few choices out there with a very low Vas.
I'll check the ESS woofer for fitment also. Since it is 10 5/8" wide I suspect it would require routing, which puts me back into wood work :nono:
