A real problem is that manufacturers today are extremely loose with the definition of "Class A". For example, in the Audiomat product, if it truly does produce 30 watts RMS per channel from two EL34 tubes, then it is impossible for it to be a Class A amplifier, as classically defined by both tubes always drawing current at all times throughout the dynamic waveform, up to maximum power output. It may be a design that extends Class A operation, but ultimately, to produce 30 watts of power, it must shift to Class B at some point. EL34 tubes are only capable of about 14-15 watts RMS power output when operating in Class A -- any attempt to produce more power will exceed the plate dissipation rating of the tube.
The only amplifier I know of that truly operates in Class A throughout its full power output range, and is quite common (or used to be), is the original Williamson amplifier -- of which the Craftsman 500 is the best working copy of imo. It is truly an honest Class A push-pull (triode) design, which is also why it only produces about 10 watts of power output. As I say, manufactures today are extremely loose with the definition of Class A operation -- no doubt for marketing purposes. But if you want one that is truly Class A by design versus a wannabe Class A designed by a marketing department, then the Williamson amplifier is the go-to standard.
I hope this helps!
Dave
