Thanks for the example anyway! I think at this point, the "common" requirement still has the Williamson ahead by a mile......
Dave
Dave
Yeah I missed the common bit and just saw push pull class AThanks for the example anyway! I think at this point, the "common" requirement still has the Williamson ahead by a mile......
Dave
Pondering this question, I've read that the Eico ST40 has a Williamson power stage and runs in class A, but It've not checked either claim.
The abuse could be flipped to the AB promotion, too. Where do we see an AB amp that is 90% of the usable power found through the class A range and the last 10% is in AB portion. Call it an AB amp for the promotional power and efficiency factor? Not very accurate. I'm surprised that hasn't been a point competition over the years.... "Our amp starts AB at 50% and theirs at 70%..."
I think the most relevant question on the issue is what happens to the SQ as the volume is raised to the point where the amp begins the transition...? A little FB dab 'll do ya.
I don't disagree, but I have seen the first in Eico ads of the time.Both of those claims are false.
Might be confusing to readers not familiar with the definition. Class AB is a class unto itself; it is not sometimes a class A amp and other times a class B amp. Rather it is its own definition of a class, called AB.There is no, 'starts AB...somewhere'.
There is no, 'starts AB...somewhere'. Its the max power condition that determines the Class. Both conducting is not the single determining characteristic.
You are using the A and AB designations as a title, and think it's only appropriate to apply them for whatever mode the outputs are in when at full power. That's only one point of operation. The class an amp is operating in is the class it's in in any point frorm 0 to full power. It's not just a title. Class B is only for amps biased at cuttoff at idle. An AB amp doesn't go from A into B. It goes from A into AB at some point, never seeing B in operation.
That's like saying a supersonic jet can't fly subsonic. They could have called it A/AB but that would have been redundant once you know how it works so they said, "Let's shorten it to just AB."
Then finally I always frown at the Williamson amplifier being regarded as having 'high NFB'.
The second looks like Mullard, simple, more direct, and better inherent stability. It supplanted the Williamson for good reasons, imo.The Williamson amplifier has several main components.
1. Input stage low mu triode direct coupled to phase inverter
2. Split load style phase inverter.
3. Intermediary driver stage between phase inverter and output tubes
4. Class A triode output tubes (triode connected KT66)
5. Very high levels of negative feedback, and a special output transformer to support it.
6. Choke filtered power supply
The EICO has
1. Input stage has a high mu triode direct coupled to phase inverter
3. No intermediary driver stage
4. Class AB beam power output tubes
5. Reasonable level of negative feedback, apparently a good transformer.
6. No choke in power supply
I think that at the time, Williamson was recognizable to hifi enthusiasts as high quality - but really, there isn't a lot of common ground between the two designs past the fact that they're both push pull tube amps.
The pentode input is optional to the topology, Marantz used it in the tube amps with a pentode wired as a triode in the front end.Mullard has a pentode input direct coupled to a long tailed pair - it's another animal. I am not sure about which is best, I think there's room for diversity in amplifiers just like anything else.
It is the same thing, the Mullard just had more gain in the front end to accomodate the 0.5V British line level standard.
There's also an expectation that the Williamson must include tapped screen OPTs, also not a requirement.
