Retrovert
Addicted Member
Well, please enlighten me Sir. I have reworked many of the original versions, and some lesser work on the reissues. And every piece of audio gear that comes across my bench sees a scope/Tek THD+N/IMD distortion analyzer.
Not to step on Douglas' toes, but as he's likely still sleeping here's a brief response.
The Vox AC30 is notorious for being fast-and-loose with the Class A specifications, and being marketing Class A (i.e. actually Class AB) instead of engineering Class A (i.e. actually Class A).
I would point to Randall Aiken's excellent analysis, complete with plots:
https://www.aikenamps.com/is-the-vox-ac-30-really-class-a
Is the Vox AC-30 Really Class A?
by Randall Aiken
There is a lot of discussion on the topic of class A amplifiers. The Vox AC-30 is always brought up as an example of a class A amplifier, but is it really class A?
The Vox AC30 has a 4K p-p OT, and if you look in the RCA receiving tube manual you will see that 8K is recommended for the plate-to-plate load in class AB at 300V for two tubes, so the optimum class AB loadline would be 4K for four tubes as it is in the AC-30.
Here's a plot of the 8K loadline for two tubes (which is the same as 4K for four tubes as in the AC-30). As you can see, it is a perfect textbook class AB loadline right through the "knee" of the plate curves, and right along the max dissipation curve (the green curve) as it would be for maximum power in class AB without exceeding the plate dissipation. This proves that the AC-30 was designed for the textbook class AB output transformer specifications as outlined in the tube manuals of the day.
The blue line shows the class B loadline, the red line shows the class A loadline. Note that the transfer from "class A" to "class B" occurs at the crossover point of the two lines, but due to the way push-pull class AB works, it would actually be a smooth, curved transition.
In order for an amplifier to be "true" class A, the output must be biased in the center (the most linear portion) of the operating region of the output tubes. However, you can't just jack up the bias on a class AB amplifier to make is class A, because the output tubes will exceed their dissipation limits, and the amplifier will fail. The only way to make the amplifier true class A is to reduce the plate voltage and readjust the bias voltage/current to properly center the output stage operation in the correct portion of the transfer characteristics of the output tubes. It turns out that EL84 tubes can take up to around 250V maximum and remain in class A operation. If this plate voltage is exceeded, the dissipation will have to be set too high to keep the tubes out of cutoff at all times, and they will fail.
The circuit below shows the same AC-30 output stage, but instead of running at 320V, it is running at 250V. The common cathode resistor was changed from 50 ohms to 31 ohms in order to bias the amplifier back up to near the midpoint of it's range (49mA per tube at this plate voltage). This rebiasing resulted in a change in quiescent cathode voltage from 10.5V to 6.8V, which means that the amplifier will clip much sooner, so the input signal had to be reduced from 0.86V p-p to 0.0.51V p-p to drive the output stage to a point just prior to clipping. This results in a quiescent plate dissipation in the output tubes of (250V-6.8V)*49.2mA) = 12Watts (right where it should be for max power in true class A operation).
by Randall Aiken
