There are of course different school's of thought on this. Yours is not necessarily incorrect, so I'm not going to turn around and say you are incorrect.
Dependent upon design, there may be all around benefits, then some benefits, with some improvements, and as well some detractions, and then maybe no noticable improvements at all?
The ears have it, what you hear, (or don't hear), another may, or may not hear.
Micro resonances can occur, its almost like taking a table, and sliding it across the floor. if the Table-Legs are better damped, those audible screeching noises would be less.
The same also applies to Tonearms. With vibrations traveling from the Stylus-Cartridge, they travel through the Tonearm, back and forth, and actually back into the Stylus. This causes smearing of the sound. The more smearing that will occur, this will impact high fidelity, coherence.
Many direct drives by design have relatively lightweight platters, but I believe enhancement can be had by maybe not the coupling of record to platter, but by coupling record to a particular platter mat.
Many as such, like particular mats, like the Herbies, and the effectiveness of coupling to such a mat can-may have variances, both good, and bad. It's then up to the listener to decide whether or not they like such influences?
Mark
