2SC1708 - 90v - 50mA - 200mW - B=250 - ft=150 - TO-92 case
The Zetex ZTX694B is a very high-gain device which works great for differential pair transistors if you need an NPN. The problem with using it in the 9090 Sansui is that the mounting holes on the driver board are all lined up in a row, and the board expects a device with the collector as the center pin. The Zetex transistors have the base as the center pin.
If you're willing to bend the leads around so they make it to the proper hole for soldering, they will work fine. Otherwise, I'd have to recommend that you look at the Fairchild KSC1845, available at Mouser.
