First time Veneer job....
That's what I'm talk'n about!! :thmbsp:
The KISS principal in action.
I was reading another thread here in the forums about another member installing the same veneer that I will be using on his Sansui case. He just installed the veneer right over the counter bored holes, drilled a pilot hole from the back, and then used his dremel with a small barrel sander to finish them off.
I will definitely be practicing on a small box with various cut outs. I got the 24" x 96" piece of veneer so I will have plenty to practice with.
I have actually done quite a bit of finish work on furniture, as well as finish trim work through my construction business. One of my favorite ways to finish bare wood is with whatever flavor stain I want to use, and then maybe 5-6 coats of rub on poly. I make my own cocktail of rub on poly because it's cheaper that way. Since I will be using the walnut faced veneer, I will most likely go without stain, and just go with the natural look of the rub on poly.
Here's a case I built and finished for my Marantz receiver that I owned. I built it from solid walnut. It just has four coats of rub on poly.
OMG!!!! Flat out gorgeous work! :ntwrthy:
I recently received the 2” walnut veneer I need to restore ( make that upgrade the vinyl factory veneer) on a Pioneer PL-117D turntable that is my most recent project. I can only hope my TT turns out as 1/2 nice as your cabinet . Thanks for setting the bar high & giving me a standard to strive to achieve!
May I ask what paint you used on the metal parts of the case to get that nice textured finish?
Thanks
PQ
Thanks
PQ
Thanks! The black textured part of the case is not metal. It's made from 1/4" project panel from Home Depot. I bought a can of spray on bed liner from the auto paint store locally, and that's how I got the textured finish.
Awesome! Thanks for sharing!:thmbsp:
PQ
sweet!! Been quite a few posts in the past week of DIY excellent workmanship and ideas.
Gives me an idea for mounting fans. In my local in the south, with power amps.. heat is an issue in summer (not to mention a compromise with a/c) It's not hot or humid enough to have to bring the stereo stuff inside... lucky so far. then get the grill going.. to cook outside on those coming hot days. :D
Okay guys, I received my walnut veneer. I practiced on my "practice" box and decided to dive right in. It took me about three hours to do the entire job, but I was very patient and took my time. Thanks to all the advice from you fine folks, I think it turned out acceptable. I will mix up a cocktail of rub on poly and apply about five coats and call it good. I had to put the cooling grill back in just to see how it looked.
Sweet! Makes me want to hunt down a vintage receiver just to use up some walnut veneer in the garage.
My first post on this forum is to congratulate you on a job well done!
That's really a handsome receiver you have there, nice to see it looking so good again.
