That makes me want to hunt down one of those receivers . How does it sound , because it looks great .
Exceptional! Your rub-on-poly really tops it off.
Now, how did you decide to handle the edge trimming????
How thick is this veneer? I'm probably mis-reading, but did you use an exacto knife to cut the veneer? Do you need a 45° cut for the corners?
The veneer is really thin. I think the pre-installed glue is thicker than the actual veneer. I did the sides first as mentioned by another member, and then installed the top so it covers the side top edges.
I don't think I could have accurately cut a 45 degree angle on the sides of something this thin.
Keizer, what was the substrate made of that you put the veneer on? Was that the original case for that component or something you made?
Thanks!
