Fisher 400 restoration
rudpra
Update got the Fisher 400 restoration kit from metalbone $85 will start in January ,I which he would have done a DVD video on the restoration and included with the kit
Its not all that bad, metal bone kit has some before and after pics, just start with the same order he describes his initial restore. If you get a bit confused search around this forum or ask in a post and eventually you will see what's going where. I found it easier to clip the part out with small cutters than solder in the replacement. Make a decent physical connection before using solder to finish the joint and test after to make sure all is good. If something is wrong you know where the issue is.
