Yes the Negatives tied together on the dual 1000uf caps is your bias voltage going to the tubes at the beginning. Follow that lead to the 300K grid return resistors and measure voltage there on all 4 resistors, and again at pins 2/6 on the output tube sockets. I want to make sure you have bias voltage at the tubes that is commensurate with what is output at the bias caps.
Pins 4 & 5 on the output tubes are the heater pins. They should be 6vAC or so across the pins. One probe on 4 one probe on 5. They will be slightly higher with out the tubes in.
