Okay, guys, old problems resolved (a detailed explanation of the work I did is below), but now I have a new problem!
I fired this thing up Friday night after verifying that my B+, IF heaters VAC, and other tube pin voltages were, for the most part, pretty close to spec (with the exception of the MPX section, where things got weird*). The specified Test Points were off, and smaller magnitude voltages were off a bit (i.e. -2.2 V spec vs. -1.11 V measured), but I assume that when I have this aligned, it will bring these back to the right level. To my delight, I immediately started pulling in strong signal, including stereo switching. I listened for about 20-30 minutes and noted some muddiness across basically the whole audible range, and what sounded like some very low frequency rumble. So, sound quality not quite what I hoped for, but I think an alignment (planned for as soon as I resolve the other issue at hand) may clean most of that up. Distant and local switching seemed to work, too. Pleased with the success, I shut my system off and went to bed.
* I'll need to go re-check, document and report back the voltages in the MPX section. I couldn't make complete sense of them when testing after my initial resto, because some voltages were in spec while others were incredibly NOT. Stereo reception brought some of the NOT spec voltages in line but pushed others out. I'll report back.
I came back Saturday morning, turned the tuner on to have some classical accompaniment for my other projects, and after about 3 to 5 minutes, the right channel dropped. No pops, no clicks, not a slow fade-out, nothing dramatic. It just stopped putting out sound.
Not the amp, not cables, definitely the tuner.
Switching the tuner function from automatic to stereo to mono had no impact, nor did the level pots on the back resolve the issue. Turning the right channel output pot all the way down reveals there is SOME signal from the left side, but it's very quiet.
The same thing happened Sunday morning. 5ish minutes of good, stereo operation, then the right channel drops.
Obviously something is failing once the unit heats up. It seems odd that this didn't happen the first night when I tested it out, but it's consistent, now. I'm not even sure where to start, since all my tube pin voltages seemed to be pretty close to right (other than MPX).
Any ideas?
Quick recap of my FM-100-B journey thus far:
Picked up this unit over the summer, thinking it had seen some work and it turns out it was never touched, save for a few tubes having been replaced. I was getting no output on either side, and tube pin voltages were pretty much all out of whack all over the place. Can cap sections tested way off, so I figured I'd just go ahead and restore the whole thing.
1. Deoxit on all pots and switches, followed up by contact cleaner with lube. Sockets cleaned. Tested and found one shorted 6AU6 tube, and two more giving me inconsistent readings. I'm not sure if this is a problem with my tester, or with the tubes, but I went ahead and replaced all three with used-but-good Fisher branded tubes. Output and MPX 12ax7s tested fine, but I swapped them with a pair of good GE 12ax7s I had on hand to eliminate variables with the NEW problem.
2. CL-90 installed on one leg of the AC line, immediately before it hits the fuse, and I replaced the 0.01uF bypass capacitor (C10 in the diagram and parts list)
3. The selenium rectifier was replaced with a Vishay single phase 600V 3A silicon rectifier. And at wall voltage, a 100 ohm dropping resistor yields 198-199 VDC at the first filter cap (spec is 195), but subsequent B+ voltages are in line. I used a 10 watt I had on hand, so plenty of power handling.
4. I was going to use a replacement can from AES, but I couldn't de-solder the can cap form the chassis with my iron, and didn't understand "re-stuffing", at the time. I used 39uF 350V nichicon caps to replace the first two sections. The remaining two are 47uF (measured 45uF) 250V unknown brand from my local shop. I added a terminal strip to provide solder lugs, and 2 additional ground points to replace the terminals of the can cap. While I did this, the 270 ohm power section resistors (R17 and R19) were out of spec so were replaced. The 470 ohm R18 resistor was also replaced, due to damage during power supply work.
Next I did some signal path restoration and upgrading.
5. Mistakenly thought the mylar caps were bad and cut them out after testing them in-situ (they all test perfectly fine). Replaced with either Dayton polypro film caps, or k40y9/k42y2 PIO caps (for signal path) and include C36, C45, C49, C69, C71 and C72.
6. Other caps replaced:
- C63 (2uF electrolytic ) - 2uF film
- C65 (8uF electrolytic) - 8uF nichicon electrolytic
- C70 (0.5uF electorlytic) - 0.47 uF film
- C210 (1uF electorlytic) - 1uF film
- **C225 and C226 (2200pF ceramic) - 2200pF high accuracy hand-matched ceramic, as part of de-emphasis network mod, on Dave G's advice.
7. Resistors (other than power section resistors) were replaced as follows:
- **R222 and R223 (22k) - replaced with hand-matched 18k metal film resistors as part of the de-emphasis mod
- R77 (47k) - replaced with 39k (actual resistor measured at 37.8k) as part of the timing constant adjustment mod. I chose this value after reading Larry's post regarding his own work on that section.
8. After all was said and done, I went back through with 90% isopropyl to clean up any flux that ran. (I plan to clean the chassis top itself using ammonia, and polish it up with Brasso. That combo worked well on my X-100-B)
Pictures to come.
