Martin -- At the very least, there appears to be some problems in your 300. In pic #1, the sine wave is very distorted, almost appearing to be clipped on the top of the waveform, with the bottom of the waveform looking rather skewed -- although this could just be camera error. In any event, this is hardly the low distortion signal that the 300 is capable of. Since this signal is taken directly from the 300's composite output, there is no intervening tuner or adapter circuitry to cause this issue. The phase linearity does look good however,
In pic #2 (signal from the tuner multiplex output at the adapter input), I'm not sure what modulation level you are using, but it is either very low, or the stray 38 kHz radiation inside your 300 is very high -- this in addition to the distorted sine wave previously mentioned.
In pic #3 (output of the 67K trap at the junction of the mixing resistors), the 38 kHz information is nearly absent from the display. You have not stated whether this display is taken from your defective adapter, or your known good one. In any event however, the display is problematic. Is the 1 uF composite coupling cap into this junction point known to be good?
Pic #4 ( taken at the output of the Left Channel balanced modulator) already shows separation problems which should not be there. If you look carefully, you can see the signal from the Right channel weaving along through the base line of the waveform. The modulators appear to be filling in the waveform with 38 kHz energy as they are supposed to. However, it's also hard to know in this pic how the amplitude level compares to that of the previous pic taken at the mixing junction. The output of the modulator should be about 1/2 that appearing at the mixing junction.
Pic #5, at the audio output of the adapter tells the tale of the poor separation. With apparently a 2:1 delta in level, that represents at best only 6 db of separation, which is insufficient for proper reproduction of stereo sound.
Looking back and comparing your same pics (although modulation level is unknown) to mine, the difference is striking -- but the differences begin within the 300.
At this point, when things are this far out of whack, I hate to say it, but the first order of business is to ensure that your 300 is operating as it is supposed to be, which at this point, does not appear that it is. Until it is known to be correct, then any results an adapter gives you must be considered as suspect.
Check your scope to make sure it has identical phase shift in the X and Y amplifier circuits, and then use your 300's manual to step it through a full calibration procedure. Only then will you know for sure that any suspect images produced by a given adapter are a product of the adapter itself, and not a product of the 300 as well.
Do you have any history on your 300 -- as to whether a full calibration was done on it when it was recapped? Recapping an audio amplifier is one thing. But recapping a 300, and then ensuring that it is operating to specification is quite another. If it is not producing a reliably accurate FM stereo signal, then using it to adjust an adapter for proper stereo operation may only make it worse.
Dave
Dave
