fisher MPX decoder troubleshoot
OK Dave,here are the findings. Connection of 19 k signal thru bridge as per manual, shows a very thin ellipse ( 2 mm at ctr of a 2x 2 inch image)scope is an old tetronix 2215. with max resistance (500k). Reducing resist pot makes this ellipse increase to a circle. Not affected by gen's filter phase adj pot.The same pattern is reproduced with a different scope(cheap one) Switched to a different 19K audio gen there is a better image ,almost a single line,a thick line without clear space in center.I looked at the tetronics manual and cannot find a phase adj point. To me looks as insignificant finding
that could be ingnored. Whats your opinion? Thanks again: Martin
Vertical deflection system band width DC to at least 50Mz
Horizontal defl system band width: X axis at least DC to at least 2Mz. same for y axis.
Phase difference between X & Y axis amplifiers +/- 3 degrees.
The scope is old and never submitted for general calibration. for example, vertical voltages are of about 25% in both channels. Hope this helps: Martin
Hi Martin -- OK, I've had a little more time to look at this. With my hasty previous look, I realize now (duh) that the phase integrity of the scope does not come into play with the filter phase linearity adjustment.
If the 19 kHz oscillator and 38 kHz doubler adjustments were all (or could be made) normal, then the only real place were there could then be problems with the filter phase adjustment is in the filter itself. It is doubtful that any of the three coils could be at fault (unless physically damaged), but the two caps in the filter could certainly cause issues.
If there are no problems with the filter, then check to make sure than nothing is modulating the right input to upset the display. This can be checked by pulling V10 to ensure no modulation of that channel exists.
Let us know!
Dave
Great Dave! the two filter caps (poliester) have been changed for ceramic and the wrong values. I ordered them and let you know when replaced. Replaced all Mylars
Martin -- With the caps changed as you described, that is almost certainly the issue. Sadly, it also suggests that whoever when through and reconditioned your unit had little understanding of exactly how the 300 operates, and the importance that various component choices represent to the unit's overall performance in generating an accurate FM stereo signal. I would strongly suggest going through the unit component by component to make sure it represents the original build intention from Fisher.
Let us know how it turns out!
Dave
High Dave Much better but not quiet yet . I get an image like 17 A ( not B) with three smaller harmonics in the background. My question how does this phase linearity affects
separation measurement , considering all (except 8 of meter adjust) appear in good shape. Always grateful Martin
Hi Martin -- The filter is important because it filters out higher order harmonics produced from the time division form of multiplex generation, and in doing so, must also provide a constant group delay for all frequencies generated within the composite signal. When that happens with a Left only signal applied, then the display of fig. 17B should result.
Understand that what figure 17B represents, is the left channel taking on the form of the sine wave, and the right signal (with a value of 0) is represented as the straight horizontal line running through the center of the sine wave. This then is a visual representation of a L only signal within the composite signal -- understanding then that with a L=R signal, the flat base line would simply disappear, since it would effectively rise up to equal the value of the left channel signal.
With that understanding then, it can be seen that any deviation of the flat line from flat (that is not produced from modulation) then represents deteriorating separation between the left and right signals. Using such a machine to align any tuner or adaptor would ultimately end up with a less than optimum alignment.
I would double check any components that relate to the frequency response of the unit, as in (for example) C44. The filter is based on the response characteristics of the circuit as a whole, so checking the integrity of any components that play a role in shaping the response of the unit should be high on the list.
Can you provide a pic of the display you are getting in this step?
Dave
Hi Dave; This is the image. I also find that the meter is way off on voltage outputs,
May be I should do some bench work through- out
Hi Martin -- Something is still very, very wrong. I'll be out for the rest of this evening, but tomorrow afternoon, I will try to post a pic of the composite output from my 300 (as set up for comparison to Fig 17B) , with the phase linearity properly adjusted, so you'll have a better comparison shot than that of the black and white shot in the manual.
Dave
fisher MPX trouble shoot
I can get this image directly from composite jack on Rt &left selector
So this would be at 1 kHz or 8 kHz from the internal oscillator? That implies problems at high frequencies (i.e 20 kHz). Generally, you want to show one complete cycle for the best analytical view presentation. More tomorrow.
Dave
fisher MPX troubleshoot
Yes. enclose pic of phase. Just noticed that freq taken from the back jack on freq counter is =0.94k and 7k. No need to adjust this, right?
Hi Martin -- In thinking about your problem, it occurred to me that part of the problem may be the equipment you are using, versus that which Fisher used to develop the pics in the different figures. As a result, a an alternate way to connect your scope will help to eliminate this possibility from your trouble shooting efforts.
The display in figure 17B is what you are shooting for, and you should be able to achieve, but most likely not exactly as Fisher shows it to be. That's because modern scopes almost certainly have a much greater frequency response than those that were likely used for the shots in the 300's manual. In servicing a specialized generator like the 300, this is where a good, thorough understanding of the FM Stereo multiplex signal can help significantly in understanding the displays produced.
As I mentioned earlier, the pic in Fig 17B is ultimately a normal Left only (R=0) display of a 20 kHz sine wave applied to the Left input of the 300, as monitored by a scope connected to the composite output of the 300. It is deceiving however, in that what the scope is NOT showing, is the 38 kHz energy in the L-R sidebands of the subcarrier, that fill in each sine waveform. The reason it is not shown is because of the bandwidth limitations of the scope used, but you can certainly see that it's "there" by way of the fuzzy, almost hairy formations on the baseline and INSIDE portions of the sine waveforms. Understand then that Figure 17B represents three distinct things:
1. The actual sine wave form itself represents the Left signal of the normal L+R portion of the composite signal.
2. The 38 kHz energy that fills in -- and conforms to -- the sine wave form represents the Left signal of the L-R double sideband 38 kHz subcarrier of the composite signal, and
3. The base line represents the R=0 portion of the L-R subcarrier.
Again, this is explained not be be repetitious, but to emphasize that the base line of any such display must therefore be absolutely flat at all frequencies within the 20 Hz to 20 kHz bandwidth for full separation to take place -- and that any MPX board aligned by a generator that cannot produce this display will produce less than optimum separation.
I have provided two pics to help you, and those who might choose to follow along as well.
Pic 1 is a shot of the (by now) infamous figure 17B display from the Fisher 300 manual.
Pic 2 is a shot of the display produced by my 300 generator, with it set up exactly as depicted in steps 1-6 in the manual, to produce a 20 kHz Left only signal, as viewed at the composite output of the 300. It is understood, and the shot depicts, that the display produced contains no pilot signal, so make sure you have suppressed that signal appropriately if necessary.
As you can see, the display from my generator in Pic 2 is substantially equal to the shot Fisher provided in Pic 1, except that my scope (Tek 475A with 275 mHz bandwidth) has the bandwidth to in fact show the 38 kHz energy that fills in the sine wave forms. I offer it as a reference for you to use in your troubleshooting efforts to achieve a proper display.
Finally, depending on the capabilities of the scope you are using, an alternate scope connection may help you to get a clearer display of the true composite signal your 300 is producing:
Connect your scope to the composite output of the 300 as directed, but in addition, set your scope for External Sync, and use the 20 kHz signal of your external audio generator to not only provide the Left only signal to the 300, but also to sync your scope. This will likely clear up any extraneous "stuff" in your display, for a more accurate depiction of the composite signal produced. For reference, this additional sync connection was used to produce the shot I took for you in pic 2.
I hope this helps!
Dave
Yeah, but that's how you learn, so I applaud you for following the thread! You pick up little bits of information you can digest here and there, and as those pieces grow, then a picture starts to form, and real understanding begins.
The concept of FM Stereo is simple enough, but as always, the devil is in the details, which is where things can get pretty complex. As a result, while the alignment of most MPX decoders will hold for many, many decades, they can also be rather easily knocked out of alignment quickly enough with indiscriminate tinkering in an attempt to fix or improve the decoder's operation. That's why it is usually best to have them aligned by a shop who has the right equipment, and knows how to use it properly -- and particularly so with Fisher equipment, because the decoders in them are just so darn good when operating correctly.
If you go back to post #4 of this thread, I give a short explanation of how FM stereo operates, which will give you a good basis to build from.
Hang in there!
Dave
Fisher MPX trouble shoot
FINALLY WE GOT IT !!! Tinkering with trigger sync ( as suggested) got the 38k energy fill in. see pic. Thank you!
Before we close, perhaps you would like to comment on the error you found in
Meter adj steps . Martin
