Congrats on getting it going Martin!
I've noted the following errors in the factory Meter Adjustments procedure, and also changed the order of the procedure to improve accuracy of the unit's meter calibration:
1. While not stated, start with the 19 kHz Amplitude Adj control set full down.
2. Step 7: The Composite Signal control should be set for a reading of 1.0 volt in the audio VTVM.
3. After step 7, then perform step 9 in the manual.
4. Finally, perform step 8 in the manual, disregarding the first sentence of step 8.
These new steps not only correct the obvious discrepancy between steps 7 and 9 in the manual, but also prevent the pilot signal from causing an error in step 9, if conducted in the order shown in the manual. This is also why the procedure should start with the 19 kHz Amplitude Adj control full down.
By performing step 8 last, the 300's meter will then read slightly higher than 1.0 volt when the 19 kHz Cal Amplitude push-button is released, as well it should -- because now it is indicating the original 1.0 volt 1 kHz signal established in step 9, but also the 10 % pilot signal established in step 8.
Why Fisher had the procedures laid out as they did is anybody's guess. But the meter scale is clearly marked as Multiplex Output, so the revised procedures I've developed then create the greatest meter accuracy relative to that signal.
I hope this helps, and good luck with your 300!
Dave
Dave
