There are a couple of possible fixes. One, if at least one end of the coil spring is visible you could slide a shim of some sort between the spring end and the hinge, thus increasing tension. Two, you could loosen the screws on the plinth side of the hinge and fit a shim above the screws and retighten, thus changing the center of gravity.
Another reason to cut up those credit cards.
