I have a review of the DD40, from a series of brief tests of a range of "Super Turntables". These were tested in the late 70's - not sure of the exact date, but it was either 1977 or 78.
ADC Accutrac 4000 Rumble -38dB unweighted, wow&flutter 0.065% WRMS, platter resonance poor
Denon DP-1700 -39.5dB, 0.05%, platter resonance fair
Hitachi HT-840 -43.5dB, 0.046%, platter resonance poor
JVC QL-7 -41.5dB 0.045%, platter resonance fair
Linn Sondek LP12 -58dB, 0.03% platter resonance excellent
Luxman PD-131 -45.5dB, 0.042%, platter resonance very good
Marantz 6300 -43dB, 0.06%, platter resonance good
Micro Seiki DD-40 -42dB, 0.055%, platter resonance excellent
Mitsubishi DPEC-1 -40dB, 0.045%, platter resonance fair
Pioneer PL-550 -42dB, 0.048%, platter resonance poor
Technics SP-10 -46.5dB, 0.04%, platter resonance very good
The Micro Seiki DD-40 was about the level of a Rega Planar 3 for rumble, and slightly better for wow and flutter. The tonearm resonance for the DD-40 with a Denon DL-103 was almost perfect - about 9Hz, and only a 4dB peak, which is excellent.
By the same magazine, the 1981 test of the Technics SL-1200MkII gave the following figures:
rumble -36dB, wow and flutter 0.04% weighted peak (no mention of platter resonance, but it probably isn't as good as the Technics SP-10). Note that the wow and flutter test for the SL-1200 was tested to the world standard that came in for the 1980's (peak weighted), and so can't be compared to the earlier figures, but it was excellent, and probably better than many in that test. It wasn't as good as any of the others for rumble, although as many of the others were higher priced, that's not surprising. It was about the same as the Rega Planar 2 for rumble, and was very slightly cheaper.
